Beefing up my 650 engine
Discussion in 'XJ Modifications' started by badmonkey, Apr 28, 2014.
  1. badmonkey
    badmonkey New Member
    Quebec city PQ canada
    Hi guys ,
    I am looking to improve horse power on my 650 maxim 83 any ideas.
    tkx
  2. ecologito
    ecologito Well-Known Member
    NASCAR Country, NC
    Get a 750. There have been plenty if discussions in this forum about out-engineer Yamaha and there best thing you can do is keep your engine well maintained. IF you want more ponies get a bigger one.
  3. Captain_Panic
    Captain_Panic Member
    Columbus OH
    4-1 exhaust and rejetting. Also lighten the bike as much as possible. Don't forget that YOU count as weight also. Go on a diet if needed.
  4. Fuller56
    Fuller56 Well-Known Member
    Colin Chapman said "more horsepower makes you faster on the straights, less weight makes you faster everywhere". That may not be 100%accurate but mostly. Colin Chapman of Lotus fame... He said it about cars but it applies to bikes as well.
  5. wizard
    Hook up a blower & run 33% nitro.
  6. TIMEtoRIDE
    Skip the 750 upgrade and go straight to a 900.
    98 HP !!
  7. hogfiddles
    or put the 818 big-bore kit in-----------
    dave
  8. BaldWonder
    BaldWonder Innocent Bystander
    Oberlin, OH
    Add a turbo from one of the seca models - or just do a full engine swap with a turbo-ed engine. A bigger engine while you're at it. Really it just depends on what you want to do and how big your budget is.
  9. ManBot13
    ManBot13 Well-Known Member
    Fairfax, VA
    Don't consider this. Turbo Seca Bottom end it beefed up for the extra boost, and it's compression ratio is dropped. Not to mention all of the knock sensor, different TCI, fuel pump, pressurized one-of-a-kind carbs, etc.
  10. Gunbunny
    Gunbunny Member
    CT
    This guy right here
  11. badmonkey
    Tkx guys for your inputs you gave me lost of things to think about.
