best oil choice/preference
Discussion in 'XJ Technical Chat' started by kapo723, Apr 17, 2013.
  1. kapo723
    kapo723 Member
    Northampton, Pa
    Almost done with my maxim. Time for an oil change, I'm just curious to see what oil everyone suggests as well as what rear oil. Was probably gonna use Castrol 10-40 synthetic. And Castrol 75-90 synthetic for the rear. thoughts?
  2. waldo
    waldo Member
    San Jose, Ca. 95125
    Its no no no synthetic. Dyno, Dyno, Dyno, Is that enough NO'S Fitz? I feel like I could have done one more but was not sure.
    Okay enough bustin your chops Fitz Ill be good for a while. Promise
  3. kapo723
    kapo723 Member
    Northampton, Pa
    Is there a reason not to use synthetic? Also what then do you use?
  4. bigfitz52
    Synthetics and current automotive oils are literally TOO "slippery." Both have a habit of causing starter clutch and drive clutch issues.
    Motorcycle-specific oils do not contain the same friction modifiers and thus are recommended.
    The factory recommends 20W40; that can be difficult to find. You can use 20W50 with no issues. Motorcycle-specific conventional oil like Castrol 4T is widely available.
  5. kapo723
    kapo723 Member
    Northampton, Pa
    I just read this from another post...
    http://www.calsci.com/motorcycleinfo/Oils1.html
    I'm not arguing, just know a lot of ppl who swear by amsoil or rotella t15w 40 Synthetics for motorcycles. This article seems to support synthetics.
    I'm torn between Castrol 4T and Rotella T 15w-40
  6. KrS14
    KrS14 Active Member
    St Marys, Ontario
  7. Foolber
    Foolber Member
    In an Igloo, on Jupiter¿
  8. Ground-Hugger
    Ground-Hugger Member
    Near Port Dover Ontario
    What about Lucas motorcycle oil it meets or exceeds the following:
    API SM, SL, SJ, SH, SG, SF, CC, CD, JASO MA/MA-2, and ACEA A3
  9. Foolber
    Foolber Member
    Yea i use lucas products like crazy
    mostly Lucas, Bel-Ray, and Yamalube
  10. maz43
    maz43 Member
    Detroit area
    I'm not picky about oil in the bike as long as it is Castrol 4T 20w50.
  11. Polock
    Mobil Delvac1300
  12. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    Amsoil synthetic motorcyle oil, 20W50 with not issues. However, unless you are really rough on the engine I think any brand name 20W50 motorcyle oil should be fine. I wouldn't put any non-motorcycle specific oil in my bike.
  13. Krafty
    Krafty Member
    Point Clark ON
    im trying out 15w40 this year just to see what its like.
    previously ive always used castrol
  14. Super
    Super Member
    This has been discussed in several forums, my choice is Rotella T, 15-40 non-synthetic diesel. I buy it by the 18l pail from Canadian Tire or WalMart when it goes on sale. I've been using it for years (during the summer) in several cars, both bikes, a 12cylinder jag etc without any issues.
    Rotella is a favorite of many here I believe, and meets motorcycle wet clutch requirements.
  15. TIMEtoRIDE
    ONE of my XJ's can't tolerate synthetic, (the 900) but the other (750) can.
    It's the starter clutch that slips, not the tranny clutch.
    But other people's XJ's have different issues,
    Which is why the only "safe" advise is to say " DINO JUICE " for everyone.
    For those willing to experiment, be ready to dump your expensive AmsOil out almost immediately, and replace it with some Rotella - T.
  16. kapo723
    kapo723 Member
    Northampton, Pa
    I think I'll just go to autozone and see what oils they have. Rotella or Castrol sound his to me. Any specifics for the rear?
  17. Foolber
    Foolber Member
  18. Super
    Super Member
    Correction (because I just changed my oil/filter) the big "pail" of Rotella T 15-40 is 18.9 litres which for the non-metric folks is 5 US gallons.
  19. kapo723
    kapo723 Member
    Northampton, Pa
    Okay guys, thanks to everyone who input on this discussion. I just got back from the stores.. as per fitz I got the Castrol 4T, but after I got home I realized it is also synthetic!? So looks like I'm going synthetic anyhow. As for the rear, I got Vavoline 75w-140 full synthetic gear oil. Again Thx to everyone :)
  20. 750E-II_29Rbloke
    South Cheshire, UK
    Hope the synth works out for you. Just be prepared to do several quick oil changes with mineral oil at the first sign of starter or drive clutch slippage, if it does affect your bike then the sooner you get it out of there the less chance of damage...
  21. kapo723
    kapo723 Member
    Northampton, Pa
    Ok Thx. I will definitely be cautious. If there is an issue, can I just flush with conventional 4T? Or does it have to be mineral oil?
  22. 750E-II_29Rbloke
    South Cheshire, UK
    conventional 4t is mineral :) there's 3 basic types of oil, (conventional, dinosaur, mineral) (semi-synthetic) and (synthetic), some types of mineral will have friction modifiers in as well though hence the need to look for a maximum spec of SG (in small print with all the VW/Bentley/SAE/API ratings)
    If either clutch begins to slip drain & flush with a couple of lots of cheap 20w40 or 20w50, finally do oil and filter again. As long as it's below SG spec it ought to be OK.
    Or you could just take it back, explain the issue & swap it for mineral SG spec, and avoid any worries (it's what I'd do)
  23. kapo723
    kapo723 Member
    Northampton, Pa
    thanks bro, I appreciate the help you guys have all been so far to me.
  24. mtnbikecrazy55
    I've always used Castrol 4t 20W-50
    It's affordable and easy to find, and performance has been satisfactory.
    The main 'benifit' of synthetics is just being able to put on more miles between oil changes, but I personally don't mind changing it more frequently, it's a nice time to peacefully bond with your bike, haha.
    I will say as well, I did the oil changes every 1500 miles for the first year I got my maxim, to help 'clean out' the innards to make up for whatever the PO had been lacking if he had.
    Pick up a new filter while you're there- both the fram and wix filters come with both new o-rings.
    I use the fram choice, same filter for your bike:
    Pick up some new plugs while you're there as well, they're only 2$ or so and then you know they're new :)
    Let us know if you need the gap specs, I any remember for sure and I'm on my phone so I don't have any of my bookmarks avail right now.
  25. kapo723
    kapo723 Member
    Northampton, Pa
    yep thats all in the mix in the next few days. the thing im really waiting on is the tank and side covers to be finished. side covers are ready for primer. we did however accidently poke a hole in the tank :-( so just finished the welding and now time for some glass for the fix, then primer and mug time :)
  26. 750E-II_29Rbloke
    South Cheshire, UK
    Rather now than 150miles down the road with fresh paint, just after brimming it with premium ;)
  27. XJOE550
    XJOE550 Active Member
    Inverness, FL
    Autozone currently has this oil in 10w-40 and 20w-50 on sale for $3.99, $2.00 off.
  28. kapo723
    kapo723 Member
    Northampton, Pa
    Lol.... This project has taken much longer than originally anticipated. Just finished podiums and on to color sanding. Here are a few pictures... FYI I made the decision to use standard Castro 4T. Tho many have had success with synthetic I decided to not chance it and stick with the safe route.
  29. BruceB
    BruceB Active Member
    Isle of 8 Flags, Florida
    AutoZone Parts has Castrol 4T 20w50 on sale for $3.99 per quart. Just picked up some yesterday...:)
  30. KrS14
    KrS14 Active Member
    St Marys, Ontario
    Wow! That's a good paint job!
  31. sektorgaz
    sektorgaz Member
    Western MA, United States
