Best soaking solution for really dirty carbs
Discussion in 'XJ Technical Chat' started by stankinjankins, Jul 4, 2007.
  1. stankinjankins
    stankinjankins Member
    Albany GA
    I was just wondering what was the best solution to soak nasty carbs in. I was going to soak them in vinegar 'thinking it isn't as harsh as petroleum based cleaners' I've got all the rubber out I think? Is there any rubber on the butterflies? anyways what would ya'll recommend.
  2. RickCoMatic
    If they have stuff that needs to be cleaned-out of places where gas has evaporated and left behind that Dark Brown Death ...
    Or if the Carbs have been sitting for years and you know vital passageways are clogged with bullet-proof residue ...
    See if you can get them into a UltraSound Tank.
  3. stankinjankins
    Albany GA
    Naw Rick no clogged passageways just super dirty on the outside. I used your carb cleaning guide and every passageway is open just super dirty on the outside is all.
  4. BlueMaxim
    BlueMaxim Active Member
    Central Mississippi
    I use Berryman's B12 or Brake cleaner in a spray can with a tube. Works great. There is rubber along the butterflies known as throttle shaft seals and also between the carbs to seal the fuel tubes. The carbs have to be removed from the rack to remove all rubber parts. I wouldn't trust them to vinegar.
  5. RickCoMatic
    Carb Cleaner and Elbow Grease.
    Parts Cleaning Brush
    Tooth Brush
    Long-handled, wooden, Artist Brush (A split second at the grinder and you have a pointed, wooden, scraper -- on the end)
  6. Fraps
    Fraps Member
    Kitchener, Ontario, Canada
    I use an artist brush and carb cleaner as Rick described - worked like a charm. I put the carb body in a tray to collect the carb cleaner run off and I recycled it for scrubbing the bodies. When done, I rinsed the carb body off with fresh carb cleaner and an air compressor.
  7. Robert
    Nylon bore brushes, a retired toothbrush, Q-tips, toothpick, screwdriver/scraper for larger areas, your options are limited to your imagination. I also doubt that vingar will harm your rubber but you can use WD-40 without harming anything. A good aqueous cleaner (such as Castrol's Super Clean) is a great place to start without harming the rubber pieces as well. Follow-up cleaning can be done with alcohol or carb cleaner.
  8. stankinjankins
    Albany GA
    OK guys i cleaned this nasty street walker. And she looks alot better I had alot of gunk on these carbs hard nasty GUNK. Even though she looks alot better im gonna clean her again to try to get her to a church going school girl. Thanks for all the great info and help guys
  9. Polock
    if a guy has a compressor, a cheap sand blast gun with walnut shells will clean
    a lot of parts real fast real good without any chemicals
