Big problems please help
Discussion in 'XJ Technical Chat' started by gdb619, May 3, 2014.
  1. gdb619
    gdb619 Member
    Albany NY
    I was riding my bike and and the engine was running and had full power but the bike wouldn't go all the sudden near the gear shift there's a hose and smoke started to come out and there was no power to the back well I think I either blew my shaft or pardon my French but f***ed up my tranny there was also a weird smell I don't know how to describe it
  2. bigfitz52
    I'd be more inclined to think the shifter is jammed between gears, possibly due to the primary chain guide beginning to break up.
    The hose near the gearshift is the crankcase breather.
  3. gdb619
    gdb619 Member
    Albany NY
    I can change gears tho
  4. midnightmoose
    midnightmoose Member
    York, PA
    So I'm trying to understand what exactly your problem is...
    Kinda sounds like you're saying that your back wheel won't turn.
    Have you checked your rear brake shoes for delamination?
    If not, take a look at this:
    http://xjbikes.com/Forums/viewtopic/t=15874.html
  5. gdb619
    gdb619 Member
    Albany NY
    I can change gears
  6. midnightmoose
    York, PA
    Ok so when you put it in gear and let out the clutch to take off, what happens? Nothing? Like it's in neutral?
  7. gdb619
    gdb619 Member
    Albany NY
    The wheel can turn just fine there's no power getting to the back wheel the bike will start but when I put it in gear no power I don't move yeah like the bike is in neutral
  8. Bigshankhank
    Bigshankhank Active Member
    Bastrop, TX
    Clutch?
  9. hogfiddles
    How exactly were you riding at the moment? Cruising down the highway, or revving the engine in neutral, or doing burnouts/wheelies, ripping up the road at redline, sitting at a stoplight in gear but with the clutch lever pulled, etc.......
    May give a better idea of what to start looking at.....
    Are you sure it's actually shifting through gears, or just the shifter moving
    Simplest thing to LOOK at is;
    put the bike on the center stand
    pull the U-joint boot back far enough to see in to the joint
    wedge the boot so you have a hand free
    rotate the rear wheel and watch to see if the u-joint turns. If it doesn't, then the shaft is broken. If it does turn, the shaft is ok, and something happened inside the tranny.
    Morn than likely, you're going to find the shaft is ok, and you broke some gear teeth inside the case.
    FWIW....... I'm west of you, just a little south of Utica.
    Dave Fox
  10. MiCarl
    Probably the clutch. The slipping heats it up, the oil cooks, the oil smoke comes out the vent.
  11. gdb619
    gdb619 Member
    Albany NY
    I can actually shift i was in 5 shifted to 1st then to neutral so I could have her toed and the bike started to feel like it was loosing a little power all day in the first 3 gears so I'd have to throttle down once I got it in to 4th it take to right off
  12. Kornbread
    Kornbread New Member
    ohio
    Sounds like a slipping clutch or something related to it to me...
  13. gdb619
    gdb619 Member
    Albany NY
    Could it be the final gear oil I I didn't change it and I don't think the guy who had it before me did to I just opened the cap and it smells kinda almost burnt
  14. randyd81
    randyd81 Member
    St Joseph Missouri
    The gear oil has a funky smell anyways. Changing it is a great idea but I don't think that is going to solve your problem. I'm leaning towards clutch issue.
  15. gdb619
    gdb619 Member
    Albany NY
    How would I check I have to take of the oil cover should I check it or wait and order the new clutch
  16. MiCarl
    If you just order parts without inspecting it you'll likely have too many/too few/wrong parts.
    Pull the oil fill plug and sniff. If it smells strongly like roasted, aged, dirty ass you cooked the clutch.
    Get a service manual. Follow the procedure to inspect the clutch.
    Order the parts you need, plus new springs even if they measure good.
  17. chacal
    Only a true expert could be this poetic. :D
  18. mtnbikecrazy55
    Put the bike on the side stand so that the oil does not come gushing out when you remover the cover, and pull the clutch cover off, check the plates.
    I'm going to guess that the friction discs are glazed and the plain plates are blued/toasted.
    If you feel the bike was "loosing power all day" I would presume it just kept slipping slipping slipping until there wasn't any bite left.
    Unfortunately for you, letting it continue to slip all day and torching the plain plates tuned an easy 75$ fix into a much pricer one considering the need to buy new plain plates.
    If you pull the clutch cover and disassemble the clutch pack to find what I have described, this is what you will need:
    - New friction discs
    - New plain plates
    - New Clutch springs (may as well)
    - NEW clutch pack bolts (5) - affordable and easy to source from your local yamaha dealer, were only 1.25-1.75/ea. iirc and you don't have to pay shipping costs compared to sourcing them online
    - New plain plates (if you got really lucky and didn't blue/discolor them, clean them up with a scotch brite pad and reuse them.
    - New clutch cover gasket or tube of ultra black RTV. (most times the original paper gasket will tear upon disassembly.
    Notes: I like changing over to fresh oil/filter when putting in new clutch plates. NON synthetic or a semi synthetic approved for use with wet clutches is what you need or your brand new clutch will slip just the same. I've had great results with Castrol 4T 20w-50 paired with a Fram CH6003 filter. i would strongly suggest changing to fresh oil in your case considering how much you were roasting the plates.
    - When you start the project, submerse your new friction discs in fresh oil, that way they'll be saturated and ready to rock for assembly.
    - In lieu of a replacement gasket, i used a thin layer of ultra black RTV to seal the clutch cover, hasn't leaked a drop. - Make SURE that that the mating surfaces are clean and free of any residual gasket material.
    - When using RTV, I torqed the cover down to 5 ft. lbs, then retourked to 7.5 ft lbs once the rtv fully cured.
    - USE a torque wrench. The cheap HF ones work well enough if you don't have one yourself or know anyone who does. The cost of the wrench will easily be justified when you don't snap off a bolt on your bike while doing other maint, be one of the valve cover bolts, clutch cover bolts, clutch pack bolts, etc.
    - IIRC (meaning check to be sure before taking my word) the clutch cover M5's crank down to 7.5 ft lbs, **SAME AS THE CLUTCH PACK BOLTS** - Many have snapped those failing to recognize the low torque value, meaning new clutch basket time and even more $$
    - Personally, I would buy a new clutch cable at this time as well and get the adjustment dialed in perfectly, a well performing clutch is a beautiful thing, and being on the side of a road with a snapped clutch cable flat SUCKS. The one on there currently is probably 30 years old. Replace the thing, why not. I've been personally very pleased with aftermarket parts unlimited cables if you don't want to spend the bucks on a oem one.
    I'll try finding fitz's clutch disc replacement tutorial thread, he took the time to document each step along the way with great easy to follow pictures, so I will try tracking that down along with Rick's clutch adjustment how-to thread.
    One last thing, although their customer service SUCKS, the cheapest place I've found for EBC friction plates and springs is powersport superstore.
    If you list exactly what bike you have (Or better yet add it to your signature like my bikes are seen on mine below vvv) I'll try finding the proper friction discs and springs for you.
    Hope this helps and a belated welcome to the site!
    Chris
  19. mtnbikecrazy55
  20. hogfiddles
    Isn't that just regular Rump Roast?
    Dave
  21. mtnbikecrazy55
  22. gdb619
    gdb619 Member
    Albany NY
    Thanks so much I'm gonna tear her apart and see the damage hopefully its not to bad got a ride planned for Saturday
  23. gdb619
    gdb619 Member
    Albany NY
    I took the clutch apart surprisingly there are 3 friction discs are bad my others disc's look good my plain plates are dark I think it's from the oil they don't really look blue I think there just dark from being in the oil
  24. Polock
    Steel doesn't turn dark from being in oil, they got real hot.
    Are they flat?
  25. gdb619
    gdb619 Member
    Albany NY
    Yeah what I was thinking is the 3 plates that are bad I'll replace the plain plates too
  26. gdb619
    gdb619 Member
    Albany NY
    Also what type of oil should I use for the final gear oil in the on the rear wheel
  27. Polock
    If 3 are bad their all bad, if the steel ones are flat use them.
    Your springs are probably shot too.
  28. gdb619
    gdb619 Member
    Albany NY
    How would I tell that there still pretty strong
  29. Polock
    Measure them. Or put new ones in and notice how much better your clutch works.
    you don't need them for Saturday but plan on it pretty soon.
  30. gdb619
    gdb619 Member
    Albany NY
    What I was thinking is replace the plates that are bad and then this winter I'd do a full clutch rebuild when I have home more money springs all plates and clutch cable
  31. gdb619
    gdb619 Member
    Albany NY
  32. JPaganel
    JPaganel Well-Known Member
    Minneapolis
    Can you actually buy separate clutch plates? All I've ever seen were kits with all the plates included. Also, a spring kit is inexpensive ($10 on eBay right now) and will help you to keep the new clutch from getting cooked.
  33. gdb619
    gdb619 Member
    Albany NY
    Yes I just got the new ones and I'll look into it
  34. midnightmoose
    York, PA
    If you're going to have the clutch cover off and the clutch apart, you might as well just rebuild the whole thing.
    Just my opinion, but usually a half-ass job will give you half-ass results!
  35. gdb619
    gdb619 Member
    Albany NY
    I would but money is the only thing stopping me
  36. gdb619
    gdb619 Member
    Albany NY
  37. bigfitz52
    That's false economy; it will only get more expensive. If you put it back together with some good parts and some failed parts, the new parts are just going to get destroyed.
    If you plan to re-use the steels (plain plates) clean them up with Scotchbrite and check them for warpage (lay them on a sheet of glass.)
    The friction plates need to be replaced as a set; and although you can probably get away without replacing the springs immediately, you will need to do it soon.
  38. gdb619
    gdb619 Member
    Albany NY
    If I run it the way I wanted to do u think I could by for a month they other friction plates don't look so bad
  39. mtnbikecrazy55
    what bike do you have? let's start there.
  40. gdb619
    gdb619 Member
    Albany NY
    1982 maxim 650
  41. mtnbikecrazy55
  42. gdb619
    gdb619 Member
    Albany NY
    Thanks I'll wait and buy them
  43. gdb619
    gdb619 Member
    Albany NY
    How long should I soak the plates for
  44. mtnbikecrazy55
    Just put them in fresh oil when you start the job and when you're ready to put them in you'll be set. Some people don't even soak them and have no issues. It's just a why not kinda thing.
  45. CapnRedbeard
    CapnRedbeard Member
    London England
    Final drive oil in uk Hypoid gear oil, not sure what you use or call it your side of the pond?
    seem the only question that has'nt been answered.
  46. gdb619
    gdb619 Member
    Albany NY
    I got the plates rush order I tried to reassemble the clutch and there is something not right about how the cover that holds the plates in doesn't sit right its almost like there's something missing inadvertently because the center screw doesn't sit right it doesn't grab the cable tight enough to pull the the clutch lever back any suggestions
  47. NEEDtoRIDE
    NEEDtoRIDE Member
    Raleigh, NC
    Are you referring to the pressure plate not sitting correctly? and I am assuming the "center screw" is the D-shaped pull rod? What I don't understand is what cable you are trying to grab? Just rebuilt my clutch this past weekend, I would recommend reading this post as someone mentioned earlier, (http://www.xjbikes.com/Forums/viewtopic/t=29541.html) 2-3 times, disassembling and starting reassembly again. Just follow bigfitz's great step by step instructions. Worked wonders for me.
  48. gdb619
    gdb619 Member
    Albany NY
    I edited my post to make it easier to understand
  49. NEEDtoRIDE
    NEEDtoRIDE Member
    Raleigh, NC
  50. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    imo like ntr said follow the write-up. the plates have to be installed a particular way. the spring bolts cannot be over torque. the throw out rod needs to be turned cw as far as it will go prior to slipping the swing arm back on the spline (both have alignment marks). hope this helps.
