Bike almost dies after emergency stop.
Discussion in 'XJ Technical Chat' started by engraverwilliam, Jun 25, 2014.
  1. engraverwilliam
    engraverwilliam Member
    Baldwin Hills, South Los Angeles
    Ive had to squash the breaks hard a couple of times.
    Both times the bike almost dies in spite of having the clutch in and geared down. I then need to accelerate right after and the bike was sooo boggy for 3-6 seconds after the emergency stop.
  2. lacucaracha
    lacucaracha Member
    Napa, CA
    Thats a doozy.
    Float heights all in spec? Do you have an in-line fuel filter?
    When you think about what's going on inside the carbs during an emergency stop, all I can think is the floats are out of spec, causing either a flooding or starvation issue.
    Maybe the vacuum line to the petcock is old and collapses under the sudden increase(?) in vacuum...
    I'd replace the vacuum line to the petcock, then give is a few tries to see what happens.
    Ride safe...
  3. OldBikerDude
    OldBikerDude Member
    Hood River, OR
    Valves in spec? floats set properly? Pet in good working order? These are the first things I would check.
  4. bigfitz52
    Float levels first.
  5. engraverwilliam
    Thanks I will see what I can do...
    I'm still new, so a carb break down is kind of out of my league for now.
    I can check the Fuel valve and vacuum line as suggested though :)
    I was looking at getting one of those see-through filters (glass and chrome looked pretty cool) last time I was buying stuff for the bike. Is this something y'all recommend?
  6. OldBikerDude
    OldBikerDude Member
    Hood River, OR
    Yes, an in line filter is a good idea. :)
  7. happydog500
    happydog500 Member
    Northwest
    How do you fit it? I don't have enough room in the line.
    Chris.
  8. OldBikerDude
    OldBikerDude Member
    Hood River, OR
    Yes you do.... You just have to get some rubber fuel line and then cut it in half and put the filter in the line.
  9. tskaz
    tskaz Active Member
    Saint Louis, Michigan
    It's a very tight fit. The smaller the better. I got a couple of the 90* filters from Len the last time I ordered.
  10. happydog500
    happydog500 Member
    Northwest
    Those filters at my local shop have a "for one or two cylinders." Mine is a 4 cylinder.
    Also, I wanted to keep my fuel line in the tab where it's supposed to go.
    Thanks for the picture.
  11. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    @OP: You have a nice bike. At some point in the near future you should tackle those carbs. They will continue to have problems until you do. Plenty of help at this site.
    @happydog: Once you install the filter you'll be glad you did.
    Gary
  12. happydog500
    happydog500 Member
    Northwest
    I have two lines coming of the cock. Which one do I put the filter on?
  13. rocs82650
    Middle Tennessee
    The line going to the carbs. The other smaller line is not a fuel line; it's a vacuum line.
    Gary
  14. happydog500
    happydog500 Member
    Northwest
    Both are the same size.
  15. bigfitz52
    Then somebody replaced the vacuum line with fuel line and you should fix that.
    Vacuum fuel valve tech: http://xjbikes.com/Forums/viewtopic/t=25058.html
    There is a line that feeds gas to the carbs (that's the one you put the filter in) and another line that goes to a fitting on top of the #3 (650/750) or #2 (550) intake manifold. That line is the vacuum signal line and should be real vacuum line not just "hose."
  16. hogfiddles
    Yup, fuel level changing too much during hard stopping. Been there.....
  17. dmlyster
    dmlyster Member
    Corvallis, Oregon
    My question may be a bit off topic here but couldn't help but notice the vacuum line off #3 for 650/750 xj's. Is there really a performance difference. My 750 came from PO with it on #2 and I've left it that way. Will I notice a difference if I move it to #3?
    Seems to me Vac is Vac.
  18. bigfitz52
    In your case, vac is vac.
    Some of the later 600s had jetting differences in #2 (where the vac line is supposed to be on the 550/600s.)
    But not on the Hitachi equipped bikes. You're good putting it on any vac spigot you want.
  19. dmlyster
    dmlyster Member
    Corvallis, Oregon
    Thx ..... as I'm still trying to get this beast to run properly. trying to eliminate any small variances.
  20. engraverwilliam
    Funny I call my The Beast as well....
  21. dmlyster
    dmlyster Member
    Corvallis, Oregon
    My Beast is unfortunately still in need of a pacemaker, and I'm unable to find the proper model.
