Bike dies after I put it in gear
Discussion in 'XJ Technical Chat' started by maliblueman, May 4, 2010.
  1. maliblueman
    maliblueman New Member
    Nebraska
    Ok so I am doing a ridgid aj 650 and it is coming along well but i have a few issues frst and foremost I can start it in netural and it idles and revs bu as soon as i drop it in gear it kill and wont start. I found the kick stand switch and the wires are cut off and I cant seem to find the wires that go to it any on got any ideas. I will try to get some pics up soon thanks.
  2. maliblueman
    Nebraska
    ridgid xj ha ha sorry
  3. RickCoMatic
    The XJ-Models are ALL equipped with Safety Circuitry and a Relay that shuts the Bike down if a Safety item is sending a signal to the Safety Relay to prevent the Bike from moving.
    Side Stand Switch
    Clutch Lever Switch
    Neutral Switch Input.
    Bypassing the Safety Circuits is not recommended.
  4. maliblueman
    Nebraska
    ok so i get its not recomended I am a ase certified mechanic just looking for some guidance on where the wires are to hook it back up where do they start where do they end
  5. RickCoMatic
    The Side Stand wires are usually in the area of the back of the Engine or around the Battery Box or Air Box.
    The Clutch Perch Switch goes into the Headlight Bucket.
    The Neutral Sensing Wire is along the path of the Neutral Indicator Light.
  6. Polock
    why am i not seeing a kickstand switch on a 650-j maxim drawing ?
  7. bigfitz52
    (because not ALL XJs had the exact same design or configuration of the safety circuit...)
  8. maliblueman
    Nebraska
    where can i get a good wireing diagram for this bike. Also if i do not have the neutral indicator light hooked up would this be enough to cause this thanks for all the help guys
  9. RickCoMatic
    Unless you visit a Dealer who is kind enough to let you look at a fully Color-coded Master Electrical Diagram for your Bike, ... the next best thing are the Brake-downs in the factory Manual.
    The Brake-downs deal with with Sub-systems and Highlight the Sub-system on the Diagram.
    It's good to have the Sub-system narrowed-down, ... But, the illustration is still a colorless Black and White Schematic-type Print that leaves much to be desired.
