bike in a box! with missing parts
Discussion in 'XJ Technical Chat' started by ford_fan, Nov 15, 2010.
  1. ford_fan
    ford_fan New Member
    Well I traded some car parts for an 82 xj 650 that a guy toke apart to fix up but never got around to. Iv been slowly trying to peice it back together and iv been beating my head agiants a wall trying to figure out how the carbs go and intake go together. The carbs have a flat side with two bolt holes and I can't figure out how to put it back together the motor has the rubber mounts but I'm missing the parts going from the carb to the filter. I considered using pod filters but I have nothing to put those on either! Anybody know what it is I'm missing that bolts to the carbs?
  2. RickCoMatic
    Use this Yamaha Site.
    Select: Go To parts catalog.
    From the Menus ... Enter YOUR Bike.
    You'll see the Exploded Views of Parts and Assemblies after selecting from the Component Parts available to View.
    In the Lower Menu you can find the Part Name / Part Number / Availability
    http://www.yamaha-motor.com/sport/myyam ... there.aspx
  3. chacal
    Fan, there are rubber boots (tubes) that use a band clamp to the rear of the carbs "throat" and then go all the way back to the airbox (they "push into/onto" the airbox openings).
    We carry all of the items that you'll need in stock, just send us a PM or an e-mail for more info.
    The two "holes" inside the carb throat openings should have brass air jets in them, those are not really "bolt holes"............!
  4. ford_fan
    ford_fan New Member
    Ok after looking closer ur right there r brass jets in the holes I just couldn't believe there was no more lip on the carbs than that to hold the rubber boot on! Now I need to find a throttle bracket and ill have the carbs igured out.... this is going to be an all winter project!
  5. Orange-n-Black
    Memphis Area
    Pssst: don't mention pods. :lol:
  6. ford_fan
    ford_fan New Member
    Yeah iv already read those posts on another thread... I'm trying to get by cheap here so tight butt has to do what he can with what he can get!! So far all I got in it is the gas to pick it up and an owners manual so I'm on a good start
  7. ford_fan
    ford_fan New Member
  8. Saber
    Saber Member
    Reading, PA
    This could be fun for everyone... you should turn this into a jigsaw puzzle on the forum. Take pictures and see who can help you fit parts together. :lol: :lol: :lol:
  9. ford_fan
    ford_fan New Member
    Well I discovered that the ignition box and the reg are missing....
  10. BillB
    BillB Active Member
    Tulsa Oklahoma
    there are plenty of parts on here
    you will find them.
