bike won't start
Discussion in 'XJ Technical Chat' started by andrew15, Apr 4, 2015.
  1. andrew15
    andrew15 Member
    Montreal, Canada
    I know it's a starter problem since power goes through the bike just fine, horn works etc.
    I put on clubman bars, they're the 30$ bikemaster ones you can find on Canada motorcycle and they're chrome... I've heard the starter uses the bars as a ground so I'm thinking that's it but I'm not sure where it grounds exactly?
    I also broke the clutch safety switch but as I understand that shouldn't stop me from starting the bike in neutral
    HALP ME XJ GODS
  2. andrew15
    andrew15 Member
    Montreal, Canada
    I've put my old bars back on and still nothing. Not sure if it matters but I didn't have grips on the bars just the clutch safety switch housing and the starter/kill switch on
    EDIT: Just checked the fuse box, had a fuse that wasn't quite in right.. Pushed it in and got spark, time to put the clubman's back on
  3. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    do you mean that the starter does'nt spin , or it spins but engine dose'nt start.
    did you "pinch" any of the wires on the r/h switch, starter or kill switch.
  4. andrew15
    andrew15 Member
    Montreal, Canada
    It was the fuse!
    Started right up, first shot!
  5. k-moe
    Original fusebox? Replace or rebuild it.
