Blinkers again....
Discussion in 'XJ Modifications' started by Andreas, May 15, 2009.
  1. Andreas
    Andreas Member
    Amsterdam (The Netherlands)
    Tomorrow i'll pick up a new set of blinkers for my Seca, knowing about the self-cancelling i used the "search" function and i found tons of info, but as i get in confusion i'd like to have your opinion to know if i understand correct.
    If i want everything working i'll have to:
    - Replace the 21w bulbs inside the new blinkers with the 27w of the originals and everything will work fine
    OR
    - Use the 21W bulbs, replace the original relay with a 2-pin unit but i will lose the self-cancelling feature.
    Assuming that, i guess a 3 pin unit that casually i got is not working, right?
    Thanks in advance.
  2. bigfitz52
    Sounds about right. Except on my Seca, I only had to switch ONE bulb on each side back to a 27W to get them to blink after installing aftermarket signals with 21W bulbs in them; they've been fine since.
