blowing gas from #3-4 carbs.
Discussion in 'XJ Technical Chat' started by davy, Apr 14, 2015.
  1. davy
    davy Member
    canada
    Hi Guys. I have just rebuilt the bottom end on my 81 Saca all is fine except gas blowing out 3+4 carbs, any ideas ?.
  2. FtUp
    FtUp Well-Known Member
    pacific northwest
    blowing from the carbs? are you running it without the air box and boots?
    FU
  3. davy
    davy Member
    canada
    I think I may have a bent valve.
    Why do you think you have a bent valve?
    What exactly do you mean by blowing gas out of the carbs?
    Does your crankcase smell of fuel? Is the oil level too high?
  5. davy
    davy Member
    canada
    I took the the valve cover off and turned the motor over and the valve / shim stayed in the down position.
