bobber seca?
Discussion in 'XJ Modifications' started by 82seca750, Dec 24, 2008.
  1. 82seca750
    82seca750 Member
    Greenville, TX
    like to know if any of you guys have seen or know of anyone that turned a XJ750RJ in to a bobber. or if you know how to lower the rear end with out cuting shocks.
  2. dqnjuan
    dqnjuan Member
    bmore, md
    I have a 750 seca bobber you can see it on the link in my sig, it hasnt been lowered yet but plan on a hardtailing it before riding season.
    I dont know how youre going to lower it without cutting the shocks or removing them for solid struts or welding on a hardtail.
  3. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    Alot of the fabricators just make solid struts to lower the rear of the bike, but you pay for it in the ride (I know first hand)
    I shortened my shocks, which isn't all that hard to do. But there are shocks off of other models that are shorter that'll do the trick. Keep in mind that the weight of each bike is a factor when using shocks off of other bikes and will make a difference in your ride. You want to look for shocks from a bike that has roughly the same weight as yours.
    Another trick I've used in the past to lower the rear end, is to fabricate shock-extenders that move the bottom of each shock back 1-1/2". That willgive you a lower stance and still have a dampened ride. Just a thought.
  4. bigfitz52
    You don't even need to fabricate, these exist and are still available, plus they show up on eBay with great regularity. A "true" hard tail bike has handling deficiencies that CANNOT be corrected due to the complete lack of rear suspension; extending the shock mounts back or going with shorter shocks is the safest way to lower the bike.
  5. yamaha4life
    yamaha4life Member
    OH---IO
    air shocks like mine....lol
  6. xulf13
    xulf13 Member
    Franklinton, NC USA
    Ok, I am looking into this as well. Does anyone know which shocks to use? or what to look for on ebayt as far as shock relocator tabs go? How about the front? How would one go about lowering that? I'm asuming cutting the springs is out of the qestion then? Thanks.
  7. leadboots
    leadboots Member
    aylmer ontario canada
  8. xulf13
    xulf13 Member
    Franklinton, NC USA
    Leadboots, that's some nice work you're doing to your bike. I've been reading thru it. But that's not what I'm after. I have a 82 xj750rj. I pretty much want a semi stock look for mine. I don't want to do a hardtail either.
