Bobber Tail light- Idea/Solution Compilation
Discussion in 'XJ Modifications' started by clark.project.network, Mar 25, 2012.
  1. clark.project.network
    clark.project.network New Member
    I chopped my xj750 and am looking for ideas for a simple custom tail light; ways to mount, aftermarket lights of the right size to work with space requirements (over fender, under fender?) etc..
    I figure many of you have already bobbed your bike and have figured out a tail light solution that works for you; why dont we get a list started of pics of some rear ends ( :wink: ) for inspiration, for anyone at this step in their build to get ideas from, now and in the future.
    What say you people?
    (If there is already a post similar to this, forgive me, I was unable to find it)
  2. hctbvum
    hctbvum New Member
    I'm trying to find an answer to this question before I chop mine
  3. mooch
    mooch Member
    Dayton, Ohio
    I bobbed mine out over the winter and I used a 2 inch bobber taillight and plate mount from TC Brothers. Here's what it looks like on my bike.
  4. iwingameover
    iwingameover Active Member
    I've got some bullet lights on mine. But it's not really a bobber.
    You could probably find something that fits in the open frame tubes.
    I've got these for my plate: http://www.customdynamics.com/illuminat ... _Tag_Bolts
    I got the ones that also light up with the brake/turn red in addition to the plate light.
  5. strat
    strat Member
    Williamsport, PA
    only real shot I have of the rear of mine...
    side mount plate with a model T tail light. both purchased from ebay. (although I believe TC Bros is carrying a similar setup now)
  6. boostenlebaron
    boostenlebaron Member
    Sturbridge MA.
    Ive been trying to figure out the same thing. In MA i have to have the brake light mount in the center above the rear tire so those neat side mounts wont work for me.
  7. clark.project.network
    Thanks for the pics guys! I too, am curious to see any center/above the tire mounted lights.
  8. Metal_Bob
    Metal_Bob Active Member
    Bourbonnais, IL
    6 inch oval led running / brake light meant for semi trailers would fit with a small metal plate near chopped zone. Chrome ring removable on this model.
  9. hogfiddles
    I cut down a harley bobtail fender. I cut down the inner edge to match the shape of my 700 fender inner edge. That allowed me to use the bobtail rack, as well as the bobtail under-fender light. All I had to do was to ground the light right to the fender, as Harley does it that way. I'll try to get a pic into my gallery this weekend.
    Dave F
  10. worm
    worm Member
    Attleboro, Massachusetts
  11. TIMEtoRIDE
    I like the simple, understated look that doesn't draw too much attention . . .
  12. JACK-BRAP-113
    JACK-BRAP-113 Member
    deadmonton Alberta
  13. worm
    worm Member
    I must have missed it, I don't see any pics or ideas for a tail light?
    the bars look good though...
  14. TIMEtoRIDE
    You have Robert E Lee's ANVIL !! ??
    george hogue likes this.
  15. worm
    worm Member
    Nevermind, I'm a dumb&ss...next time I'll look at page 2!
  16. clark.project.network
    Good pics. Keep 'em coming!
  17. trgrhappy
    trgrhappy Member
    Post Falls ID
    I went with a 6" cats eye on the back of my 550 Secabob
  18. sethoneal7
    sethoneal7 Member
    Dallas Texas
    Did you have any issues wiring this... Loads and stuff? I have a cafe seat ready to moint and no clue about the tail light.
  19. colehole
    colehole Member
    Panama City, FL
    My tail piece is absent here but I used Harley turn signals minus the stems with red lenses that bolt through the frame
    Orange-n-Black likes this.
  20. Josh phillips
    Josh phillips Member
    Bettendorf, Ia
    worm hasnt been on since 2012, not sure he will see my message. He has covers over his exhaust pipe, obviously for rain and, do they blow open? Does anyone know where to get them?
  21. Skwerly
    Skwerly Member
    Yucaipa, CA
    I love these little dilemmas; it's what makes hobbies like this fun! :D Some cool ideas, let's see more.
  22. Orange-n-Black
    Memphis Area
    Like this idea, reminds me of the 883 Iron Sportster.
  23. colehole
    colehole Member
    Panama City, FL
    Here's a couple of more shots with my seat and tail piece on
  24. k-moe
    The header wrap you're seeing was originally meant to help keep heat in the pipe, which improves exhaust scavenging (mainly in 2 strokes, but is also helpful in 4 strokes). It's not there for rain protection (and can actually cause the pipes to rust due to moisture retention), but mainly for looks (and sometimes to dress up pipes that have pitted chrome, or scratches). The wrap gets soaked in water before fitting it, and is held on each end with either stainless steel clamps (the fancy new way), or with safety wire (the cooler old way). Header wrap can be purchased at any auto parts store, or from many online shops.
  25. Josh phillips
    Bettendorf, Ia
    I wasn't talking about the wrap, I saw somewhere,cant find the pic on here now but the pipes went up vertically at the back of the back there was a hinged end cap on each pipe.
  26. Josh phillips
    Bettendorf, Ia
  27. colehole
    colehole Member
    Panama City, FL
  28. k-moe
    Ahhh... An exhaust flapper. Any good farm store will have a selection, as will a tractor dealership. Keep in mind that they do effect backpressure somewhat, as the exhaust gasses are what causes the flapper to open. They also clatter, which isn't an issue on a tractor, but you might not like the noise on your motorcycle. You can see the clamping bolt in that pic, along the lower radius of the flapper.
    Josh phillips likes this.
  29. Skwerly
    Skwerly Member
    Yucaipa, CA
    I like that black/copper color scheme. :D
  30. Josh phillips
    Bettendorf, Ia
    It's a unique look for sure I had just never seen anyone with those on their exhaust.
  31. Orange-n-Black
    Memphis Area
    Here's a pic of one.
  32. Skwerly
    Skwerly Member
    Yucaipa, CA
    That's a sweet ride.
  33. Josh phillips
    Bettendorf, Ia
    Hell yea I like that look!
  34. george hogue
    george hogue New Member
    white swan wa
    You guys are lucky....I live in Washington state and apparently it's not legal to mount your license plate sideways....so my choices for a nice looking mount on my future bob will be not as appealing i think lol
  35. hogfiddles
    not legal here, either......but people do it anyway. I don't know how much the cops really watch for that thought......
  36. Skwerly
    Skwerly Member
    Yucaipa, CA
    Yea I doubt it's actually legal anywhere, but folks aren't hassled much for em.
  37. FtUp
    FtUp Well-Known Member
    pacific northwest
    even though it's not legal here in Washington, I have seen people do it. sure you may not get pulled over for it, unless an officer decides he needs probable cause just to hassle you.
    FU
  38. Polock
    they made the side plate legal here in PA last year IF you get a special plate that has the letters and numbers sideways. letters and numbers horizontal but plate vertical. i think it's about 30$ extra, anything for money
  39. george hogue
    white swan wa
    Wow i wish they had that option here.....i'd pay for that......maybe i should ask huh
  40. george hogue
    white swan wa
    Most header manufacturers won't warranty their product if you wrap them but i guess it has less or no effect on stainless.......who'd wrap stainless though lol
  41. k-moe
    Anyone who wants to increase exhaust scavenging (an inexpensive way to help optimize the intake charge; free HP). I wouldn't bother on a street bike. I would carefully consider it on a four stroke race bike. I would definitely do it on a 2 stroke drag bike.
  42. Skwerly
    Skwerly Member
    Yucaipa, CA
    Plus, on some ratted out bobbers it looks wicked.
