bogs out
Discussion in 'XJ Technical Chat' started by Doug, Jun 14, 2007.
  1. Doug
    Doug Member
    Hamilton Ont
    when I hit the throttle hard engine starts bogging out...when I bring up the throttle slowly it seems ok ...this happens in neutral and when riding
    any ideas????
  2. Alive
    Alive Active Member
    Queensland, Australia
    Could be running rich... What colour are the ends of your sparkplugs?
  3. RickCoMatic
    Sounds like the Pilot Mixtures are just a tad RICH.
    Make a "Road Tweak Tool"
    Take one of those small, CRAFTSMAN, screwdrivers ... the kind with the "Metal Pocket Clip" and fabricate yourself a "Tweaker"
    Cut-off the plastic handle right down to the shank.
    Grind-off half the business-end and grind a new "Pilot Screw fitting" end on it.
    Take it with you and go ... Road Tweak.
    Go someplace where you can do the tweaking.
    An industrial park when everybody is gone for the day ... like that.
    Run some test runs.
    Tweak - IN ~~> One eyelash at a time on all four -- each run.
    You'll find the SWEET SPOT in short order.
  4. tonyp12
    tonyp12 Member
    TX
    OR use a short enough and small enough screwdriver like I do and you won't need to lift the seat, unless of course you have really big hands.
  5. RickCoMatic
    Must be more room to tweak on a 550.
    The 2 and 3 Carbs on 750 have gas tank almost sitting on them.
    Plus I do have big hands.
    And I got stuck, bad, when I tried to tweak my idle and got my wrist watch snagged on the airbox beauty piece.
    I got blisters on my knuckles to prove it!
