bowl drain screw removal
Discussion in 'XJ Technical Chat' started by amiel1157, Dec 5, 2021.
  1. amiel1157
    amiel1157 Member
    Philippines
    finally after 2hours i remove the drain screw.. acid did not work, heating did help.. i will be using the hex allen head on all 4 bowls now.
    Jetfixer and Huntchuks like this.
  2. amiel1157
    amiel1157 Member
    Philippines
    i used a cobalt drill bit as guide for the easy out bit..
  3. XJ550H
    I like to use the square style easy out. I think that when you drive it in with a hammer blow or two it helps loosen the crud
    amiel1157 likes this.
  4. amiel1157
    amiel1157 Member
    Philippines
    true! square has more "bite"
