Bowl modification?
Discussion in 'XJ Modifications' started by HalfCentury, Nov 15, 2008.
  1. HalfCentury
    HalfCentury Member
    Virginia Beach, VA
    Has anyone considered adding a window to the back of the float bowl?
    I would like to be able to look at the back of the carbs and SEE if the fuel is at the proper height.
  2. bill
    bill Active Member
    Raleigh, NC
    Never gave it much thought. My Dad would say just another thing to break.
    I'd be worried about getting a good seal to prevent leaks.
  3. bigfitz52
    You could machine a nice slot with a little groove in it and cast it in resin. Then grind to the shape of the float bowl and polish smooth. Might actually work INITIALLY but I'd be worried about long-term disintegration. Or, you could get some copper tubing, and...
  4. HalfCentury
    HalfCentury Member
    Virginia Beach, VA
    Here is a thought
    Two pieces of transparent fuel line.
    One piece connected from bowl #1's drain to bowl #2's drain.
    The middle of the fuel line is secured above the top of the bowl.
    Same for bowl #3 and #4.
    Then open the bowl drain screws.
    This should only take a few minutes to cobble together.
  5. SQLGuy
    SQLGuy Well-Known Member
    Sounds nice, but I don't think the level would be accurate if the top of the tube wasn't open to air.
    A clear plastic bowl would be a nice aftermarket offering, though.
    Or, just jettison the carbs and FI it!
  6. wizard
    The problem there is that the fuel level is app' on the gasket line.
    if you realy want a visual aid, 4 clear tubes from the drain, to x4 manifold, single copper tube going up through the tank to vent at the top.
  7. RickCoMatic
    What good reason is there to compromise a component part with modifications that would be at risk for leaking fuel?
    You guys can dream-up some pretty scary stuff, ... huh?
  8. HalfCentury
    HalfCentury Member
    Virginia Beach, VA
    The reason is that you can't know for sure exactly what is going on inside the carbs. A window into the carbs would make diagnosing problems so much simpler.
  9. kd5uzz
    kd5uzz Member
    How about a bowl (or a set of bowls) that you swap on when needed?
  10. Polock
    since there's a window in the master cylinder thats more important than the float bowl, i don't see why not
    but it would be too dark in there to see anything, maybe some led's in the bowl that come on when the floats open, green would be nice
  11. boomer
    boomer Member
    St.Catharines , Ontario, Canada
    Hi,
    There is already such a bowl out there. I have clear bowls on my Kawasaki ,they are 38mm "Lectron Carbs". There are a couple of pics of my 72' Kawasaki H2 Triple 8O on this site in the forum section, (other motorcycles) , (cool Kawi cafe, Dec 30th) you can see them in those pics. Better in the second pic.
    Boomer
