Brake fluid sensor
Discussion in 'XJ Technical Chat' started by jpcville, Jun 9, 2014.
  1. jpcville
    jpcville New Member
    Central VA
    1981 XJ 750 Seca
    The brake fluid warning light has been on since I bought the bike. I have torn down the brakes and will be rebuilding the MC and calipers as well as replacing the brake lines. How can I tell if the brake fluid sensor is ok now that my electrical system is all unhooked? I did clean out some dirt and grit from around the float and base of the sensor.
    Is there a way to single out the critical wires so I can test the sensor without reconnecting all the wires on the harness?
    Thx
