Brake Pedal tension spring question
Discussion in 'XJ Technical Chat' started by xjazz, Dec 5, 2010.
  1. xjazz
    xjazz Member
    Pennsylvania USA
    I've just replaced my rear brake tension rod, and in the process, had to remove the brake pedal. The short spring (2 1/4 ") in the picture popped off during the process, so I didn't see where it attached. It appears to attach to a mount mount on the frame (shown in photo) and the brake pedal assembly.
    However, the spring does not have any tension when I hook it up like this.
    Can someone tell me what I'm doing wrong? Thanks.
  2. xjazz
    xjazz Member
    Pennsylvania USA
    OK, I got it. Seems like once the pedal was put back on and everything reassembled, the proper tension is now on the spring.
