Broken bolt, broken bolt, broken bolt...
Discussion in 'XJ Technical Chat' started by anachronism, Sep 11, 2016.
  1. anachronism
    anachronism Member
    Durango, CO
    I'm starting to get really concerned with how easy bolts are breaking off in my Bike.
    In 3 months of ownership, I've broken 2 exhaust studs, the pinch bolt on the rear tire, and now one of the bolts securing the gauges. They have all snapped with ridiculously low levels of torque applied.
    I've worked on plenty of vintage stuff, but have never seen it this bad. I live in Colorado and generally don't have corrosion issues. I'm aware that dissimilar metals will galvanize together, but they aren't sticking, just snapping like I am twisting matchsticks...
  2. Toomanybikes
    Tsawwassen bc
    If PO was heavy handed some of those bolts have been over stressed.
    Exhaust studs are one thing that heat and time will weld together. And if the exhaust is aftermarket some owners do not install new gaskets, they just keep cranking on the old ones until they stop leaking
    Good luck with the next thing you take apart:)
    Jetfixer likes this.
  3. GoCrazy
    GoCrazy Member
    Poland
    I am currently rebuilding my 1990 XJ600 and so far I've broken 3 exhaust studs and one pilot screw. Now I am like 95% finished and still wondering what else might go wrong :)
  4. anachronism
    anachronism Member
    Durango, CO
    I understand that the exhaust studs are going to be weak as hell given that they are undersized and go through lots of heat cycles- along with welding to the heads due to steel vs. aluminum.
    But, I have no understanding of the other stuff. None of the bolts that are snapping even give me the indication that I am even cranking on them- like 5 ft lbs is twisting a bolt in half...
  5. Polock
    don't even try to take a screw or nut off of one of these without putting Kroil or 50/50 ATF/ acetone or lacquer thinner for at least a day
  6. k-moe
    ^ Applying pentrating oil is a must.
  7. anachronism
    anachronism Member
    Durango, CO
    I think I'll have to make that SOP.
    I also think I'm wanting to replace basically every bolt I remove.
  8. GoCrazy
    GoCrazy Member
    Poland
    Remember to use loctite/ right type of grease. Speaking of studs, I used a ceramic grease (up to 1200 Celsius degrees) which is also recommended for ABS and oxygen (lambda) sensors. Beware of copper grease in case of steel studs - steel + copper + aluminum = bad combination :)
  9. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    PO could have used threadlocker on everything?
    Penetrating oil is a must
  10. Jetfixer
    Either that or Moose Cholock got real crazy over torqueing EVERYTHING... I use Locktite never seize all we used on the aircraft !! You cussed the last guy who did not put it the borescope inspection plugs ....broke more extension and swivels than I can count removing these on CFM-56 and CF-6, CF34-8 and PW2000/4056 sorry just remising , since I went to management I don't get my hands dirty like I used to 30 yeas have flew by.
  11. anachronism
    anachronism Member
    Durango, CO
    No. It isn't so much that the bolts are stuck as it is that they seem ridiculously weak. Twisting apart with almost no torque...
  12. k-moe
    That is on purpose. The Japanese developed their fastener standards with a severe materials shortage to deal with. It's much less expensive to have a fastener fail and then extract it than to damage a machined casting.
  13. chacal
    Interesting, where did you learn about that?
  14. k-moe
    I don't have a specific point-source for that information. It's just what's been relayed to me by a few machinists and engineers that I know.
  15. Polock
    i'm sorry but that makes no sense in so many ways
  16. k-moe
    It really does make sense. Overtorquing a fastener and having threads strip out or a casing crack is big $ if it happens often. Production costs go up when parts break. Remember that the fancy torque-limiting drivers hadn't been invented when the fastener standards used on our bikes were being developed . The U.S. standards addressed the issue by allowing the driver to cam-out of the fastener (I'm specifically thinking about Phillips head screws). The Japanese took a different route. Both have advantages and disadvanages. Both lead to the same goal; keeping the expensive parts from turning into scrap on the assembly line.
    Now, whether or not what I've been told is the whole story or not; that I can't say.
  17. Polock
    steel in the 80's was so cheap the US mills were shutting down and Japan was selling it for less than it cost to make.
    metric screws are the same today as they were back in the day, and they don't fail but left untouched, in 2050 they will
    it's even cheaper to use a better fastener that won't fail in the first place.
    i bet none of the bolts broke 30 years ago and Yamaha didn't care what happened 30 years in the future
  18. k-moe
    So it can be overtorqued by an apprentice assembly line worker, and strip out or crack an engine case that then has to be scrapped?
