Buell Headlights?
Discussion in 'XJ Modifications' started by ST0CKM0NK3Y, Oct 2, 2010.
  1. ST0CKM0NK3Y
    ST0CKM0NK3Y Member
    Berkely Michigan
    So i saw pics of these Buell headlights and have an idea for them but i cant find anywhere to order them. Does anyone know where i can find these? I know the part number is Y0421.1ADA but im having no luck finding them anywhere. Heres a pic of them on a kawasaki. [​IMG][/img]
  2. Lewis
    Lewis Member
    Sherbrooke, Qc
    There's something very similar on evil-bay for ±125$. Search for dual twin headlight in the motorcycle parts section...
    Keep us updated ;-)
  3. Orange-n-Black
    Memphis Area
    Check J&P Cycles under the Harley/Buell tab.
  4. Brockzila
    Brockzila New Member
  5. quikcobra
    quikcobra Member
    Orlando Fl.
    I was just about to come say im sure you can get a street fighter front to match for cheap.
  6. ZaGhost
    ZaGhost Member
    Dartmouth, Nova Scotia
    Big difference between the Buells and the Dominators.
    Buells are cheaper, just drop into a Harley/Buell dealer and order.
    Have 1 low beam and 1 High beam....
    Dominators take a Hi/Lo H4 in each side.
    So it doesn't give you that 1 light out look on low beam :)
  7. streetmaster
    streetmaster Member
    How much more lighting does the dual headlight setup give as apposed to the single 7" headlight that mine came with, there kinda growing on me.
  8. ST0CKM0NK3Y
    ST0CKM0NK3Y Member
    Berkely Michigan
    Ok heres a second question, What if i got fog lamps for an automobile and wired them into the factory harness? Would they be bright enough? Cause if they are that might be the cheaper way to go. Plus i can get the right diameter lens im looking for.. Any thoughts?
  9. zap2504
    zap2504 Member
    Middletown, PA
    Your OEM headlight has a H-4 bulb; 55W low beam, 60W high beam. [You also have a 35W fog light.] Do not exceed this with the OEM wiring harness.
    Would after-market auto fogs be bright enough? Maybe if they were the same wattage - but would definitely have a different beam pattern that may not illuminate the road adequately (fogs usually have a vertical cut-off so the light is not reflected back). The Buells would probably be the easiest to install as they would have the same wattage draw; the dominator set would probably provide better illumination (with the dual high/low bulbs) but would require wiring upgrades. You could also look at stacked HID lights (more lumens, less watts).
  10. ST0CKM0NK3Y
    ST0CKM0NK3Y Member
    Berkely Michigan
    ok thanks man! Im gonna save up and order the buells. I think thats what will give me the most bang for my buck. (which isnt much right now..) haha :D
  11. ST0CKM0NK3Y
    ST0CKM0NK3Y Member
    Berkely Michigan
    Got them, had to go through about 30 sites though.. hahah Ill post pics soon.
