Cafe project info please
Discussion in 'XJ Modifications' started by streetmaster, Aug 29, 2011.
  1. streetmaster
    streetmaster Member
    Anybody know if there are differnces between the seca, and the maxim frames. because im thinkin about heading the Cafe racer direction with my maxim :idea:
  2. zap2504
    zap2504 Member
    Middletown, PA
    I believe the XJ750 Seca/Maxim frames are very, very similar (possibly different side panel mounting points). The tanks directly interchange; the seats/side panels do not. Both have leading-axle front forks (not real cafe-looking). I guess it depends how much of a purist you are (but that would require a British twin, not a Japanese 4 :p ). Can't say about the XJ550/650 but I do know that the Maxims for both have leading-axle forks and the XJ650 Seca has those cool knee indentations and flat tank/seat base that look OEM cafe to me.
  3. twr3cks
    twr3cks Member
    Portland, Oregon
    I'm no expert but I was told as well that the tanks are a direct swap.
  4. twr3cks
    twr3cks Member
    Portland, Oregon
    I was originally going the bobber route but decided to go cafe/fighter/bobber. WE'll see how it turns out, but I've been looking for a good seca tank. If I good seca tank. If I get my hands on one soon, I'll post pics, etc.
  5. bigfitz52
    In all 3 displacements that both models were offered in, the frames ARE different. They're very different when it comes to the 550 and 650s; the 750s are the most similar between Seca and Max.
    Generally speaking, the Maxim frames sweep down toward the seat/rear; while the Secas tend to be more level.
  6. twr3cks
    twr3cks Member
    Portland, Oregon
    Yes but I was told that all 3 frames have the same style under the tank, meaning the 1 to 3 pipes/rails. I could be wrong, and if necessary, I'll just modify it.
  7. RoadRash
    RoadRash Member
    Exactly what Fitz said, although that doesn't mean the Maxims can't be cafe'd. I did just the very thing with mine and it turned out rather nicely. The trick is to work with that dip in the frame in the seating area, and alter your rake, through adjusting your forks through the trees and slightly (SLIGHTLY!) longer rear shocks. Can't go silly with jacking the rear, as you will throw the driveshaft geomtery off, and prematurely wear your u-joints.
    Anyway, here's mine. hope this helps you envision things:
  8. twr3cks
    twr3cks Member
    Portland, Oregon
    this certainly helps amigo, that's a nice ride
  9. TIMEtoRIDE
    Did you put something slick on your sidewalls - - RoadRash ??
  10. RoadRash
    RoadRash Member
    Thanks.
    I had just sprayed the tires with some of that foaming tire stuff prior to taking the pics, that's all.
  11. PTSenterprises
    PTSenterprises Member
    NEVER use tire shine/foam/dressing products on your tires.
  12. SoCalChilio
    SoCalChilio New Member
    Encinitas, CA
    [​IMG][/quote]
    Where can i get those rear sets?
  13. RoadRash
    RoadRash Member
    I'll decide whether to or not, thank you.
  14. RoadRash
    RoadRash Member
    On the Do The Ton forums, there is a member, Durgam K. He makes them. He has threads up in the For Sale section, there.
  15. Polock
    a better thing to put on sidewalls is liquid floor wax, it lasts longer and it's safer
  16. streetmaster
    streetmaster Member
    Where can i get those rear sets?[/quote]I dont think that the maxim tank would look all that bad with a set up like yours, which is what im goin with.
  17. grunt007
    grunt007 Member
    Whow! What a cool re-design to say the least. That looks like a 750 XJ Seca tank on there is it and where did you get those emblems on it? Those really set that Black tank off to say the least. Heck, I think that looks better than it did new. Keep up the good work Buddy, I think your SMOKIN TO SAY THE LEAST! GRUNT007, 81' XJ750 Seca R, Mi.
  18. Maxim-X
    Maxim-X Well-Known Member
    London Ontario Canada
    From looking at the picture......tell me those rearsets are not mounted to the moving swingarm are they? 8O
    What do they look like from the other side?
  19. RoadRash
    RoadRash Member
    You'd have to check with a Do The Ton member by the name of Durgam K. He makes these rear sets.
    Thank for the kind words, Grunt. Those decals were something that I custom designed in Photoshop. I then sent the digital file to an online printhouse. They cut them to shape and everything for me. didn't even have to cut off the extra material. After that, I clearcoated the tank with Spraymax 2K clear. It is a 2-part clear, but comes in a spray can. Best paint bombs I've ever used and protects the tank from gas spills, quite nicely!
    Maxim-X, no those rear sets aren't mounted to the swingarm. Just the shot. I retained the passenger footpeg brackets to give them something to mount to. I fashioned the aluminum plates behind the sets, because the brackets are empty in the center, and that was exactly where I needed to optimally place the rear sets.
  20. inet101
    inet101 Member
  21. inet101
    inet101 Member
    That one does look like a good ride......
    Very nice!
    Don't want to take it to work tho......
    Real good chance ya will never make it there......who wants to end the ride?... :D
