Caliper issue on 1981 650 Maxim
Discussion in 'XJ Technical Chat' started by DanP, Jun 21, 2007.
  1. DanP
    DanP Member
    Newmarket, Ontario
    Hi guys / gals,
    I changed the fluid for the front brakes, bled the lines and everything. With the bike on the center stand and lifted off the front tire, it is difficult to spin the front tire. In other words, they're on when not suppose to be.
    I checked the handle and the proper play is there. So, I took the caliper off and the piston didn't seemed to be seased. I was able to push it back in with a "C" clamp rather easily.
    I did notice that before I took the caliper off the bike, it was on solid. Shouldn't it be free to move so that it centers itself on the disc?
    Unfortunately, the bike is at our shop, and I'm home... so I can't check if one pad as worn faster then the other.
    Any help, insite, is greatly appreciated.
    THanks,
    Dan
  2. RickCoMatic
    Dan:
    The Caliper is supposed to Float.
    There's two "Piston-like" -- Travel Rods that extend into two Cylinders.
    When the brake is put-on ... the Caliper is supposed to Pinch the Rotor with BOTH Pads as the Caliper moves to allow it.
    If the Travel Rods are stuck in old grease ... that doesn't happen and only the Pad being pushed by the Caliper Piston makes good contact.
    Look at this thread:
    http://xjbikes.com/Forums/viewtopic/t=5007.html
  3. DanP
    DanP Member
    Newmarket, Ontario
    Hey Rick, thanks for the link, but my caliper looks nothing like that one. It mounts to the left fork with one long bolt that goes through the caliper. On this bolt is a bushing as long as the caliper.
    I really should be writing these posts when I'm near the bike so that I can describe this better.
    So we're certain the caliper moves on all models?
  4. shaun81xj650
    shaun81xj650 Member
    Mount Joy, PA
    I have a 81 xj 650 and yes.....the caliper floats. mine has alittle play from side to side.
  5. DanP
    DanP Member
    Newmarket, Ontario
    That's what I thought. Looks like the PO had tightened it so much that there was no play at all.
  6. RickCoMatic
    Oh ...
    The OLD-old one.
    Best thing to do is take-out the center sleeve and clean-up the sleeve and where it fits in the caliper.
    Then, do the real restore on the caliper ... where the Brake Pad "Ears" fit.
    Super Clean
    Scrape
    Sand or Dremel the "Ear Channels" as nice as can be.
    Dress the "Ears" on the Pad with a Dremel and fine sanding tool. Make them want to slide.
    Chuck the Pin in a drill and put an especially fine, new, surface on it.
    400, 600, 800, 1000 and finish it off with 1200 Wet with WD-40.
    The finishing touch is to roll 400, 600, and 800 inside the hole in the Pads that the Pin passes through.
    Then, when you pull the Lever and put the hydraulic pressure to the Caliper Piston ... everything that's supposed to move, down there ... ain't got NO reason not too.
  7. DanP
    DanP Member
    Newmarket, Ontario
    Thanks for the info rick. I'll do all of that. I new it was strange for a caliper not to move.
    Thanks again.
    Dan
  8. MiCarl
    On the 650 the caliper doesn't slide, it pivots around that mounting bolt to center itself on the disk. Look at the diagram:
    When the caliper squeezes the pads (6) against the disc the disc pushes the pads up against (part 14) which actually rides in the ear on the LH fork. This transmits the braking force directly to the fork without the caliper carrying the load.
    The caliper pivots around the sleeve (9) to stay centered on the disc. The bolt (11) should be tight - NOT LOOSE. The sleeve prevents the tight bolt from locking the caliper.
    When I got my 650 Maxim the washer (7) was missing. This causes the caliper to ride too high and binds the pads against part 14 and locks everything up.
    When you say the PO has it on too tight - is that because you are missing the same washer?
  9. Altus
    Altus Active Member
    London, Ontario
    Another option - and one I've seen - that can cause this is improper mounting of the front wheel.
    Proper procedure is to tighten the axle nut FIRST, then the pinch bolt SECOND while making sure the brake disc is centered in the caliper.
    If someone was putting it back together and tightened the pinch bolt, then the axle nut - what happens is the disc doesn't ride properly in the caliper, and can even be rubbing up against the caliper housing itself! This causes a constant drag, and poorly performing brakes.
  10. DanP
    DanP Member
    Newmarket, Ontario
    Bingo! Thanks MiCarl. I'm missing the plate washer. Here's the diagram from my service manual. It's labeled as # 6 on mine, but we're talking about the same thing.
    Does anyone have the exact dimensions of this plate washer so I can replace it?
  11. DanP
    DanP Member
    Newmarket, Ontario
    On further inspection, I have one plate washer, and the PO used a much larger one for the top, as you can see in my picture. Are both plate washers suppose to be exactly the same size?
  12. Altus
    Altus Active Member
    London, Ontario
    That doesn't look quite right - I'll check on mine at home at lunch and will report back
  13. DanP
    DanP Member
    Newmarket, Ontario
    Altus,
    That would be great. Thanks man.
    Also, what can I use to clean the caliper out now that I have the piston out of the housing? There's some dried up gunk on the inside, etc. Carb cleaner? brake cleaner???
  14. Altus
    Altus Active Member
    London, Ontario
    Brake cleaner - always always always with brake parts.
  15. MiCarl
    Well, I just got some fender washers from the hardware store and stacked them until the pads didn't bind.
    The top washer is close to an inch in diameter if I recall correctly. There is a dust seal (o-ring #7 in your diagram) on the top of the caliper that rides on it. I suspect you have the correct washer there. I'd clean the crap off and make sure the o-ring is intact.
  16. Altus
    Altus Active Member
    London, Ontario
    Okay - sorry for the delay - have checked, and mine DOES look exactly like your picture above - so that sure does look like the correct plate washers you have there.
    Although I haven't pulled my caliper off in a while, I can't say as I remember that O-ring being there...
  17. RickCoMatic
    I love O-rings.
    If you go to the Hardware Store and buy some big, fat, neoprene O-rings ... you can fit them in the channels of the Shift Lever Rubber.
    Then, shoot-on some Armoral.
    When the Armoral dries ... you'll have some synthetic protection against leaving that ugly stain, the Rubber Part does, to your nice Cowboy Boots.
  18. brucem
    brucem New Member
    Georgetown, Ontario, Canada
    Before you assemble the caliper make sure the piston is in good shape. On previous bikes I have seen the chrome surface lift and flake off. When cleaning things like caliper pistons and sleeves etc. I tend to use a buffer wheel on the drill press with jeweler's wax. When the surface is done properly it is very smooth, the only trick is to pollish until no wax remains in the little imperfections.
  19. Doug
    Doug Member
    Hamilton Ont
    having a hard time getting the piston out, seized up big time....any tricks ??
  20. RickCoMatic
    If the Piston won't budge from the Hydraulic Pressure supplied by the Bike's Master Cylinder you:
    Try pushing it out with a line hooked-up to a high-pressure grease gun ... or,
    Bring the Caliper and the Banjo Bolt to an Automotive Brake Specialty Shop.
    (Have a pretty girl bring it in and they'll "Stop-the-Music" and fight over who gets to do it.)
    Or, ... My favorite.
    On the way to the Brake Shop ... stop-off at Duncan Donuts and get a few Medium Blacks with all the fixings on-the-side.
    Hit the Brake Shop with the rack of Coffee's and stuff in one hand ... and your Brake Caliper in the other.
    Tell the busiest, dirtiest, sweatiest guy, wrestling with the most thankless brake job that God sent you with Coffee for him and his pals. Black with all the fixings on-the-side. Just for you! By the way ... while you're enjoying the Coffee ... God also wants you to hook-up this little Caliper to His bike and get the Caliper Piston out! He sent me to see the right guy; right???
    Who's next; please?
    Alternator Brushes ... Yes, we have them!
  21. DanP
    DanP Member
    Newmarket, Ontario
    Yup, turns out I had the right one after all. I've cleaned everything, and it moves perfectly now.
    My big problem is I can't get the system to presurize. Yesterday, I tried for an hour and a half with no luck. There's no more bubbles coming out of the bleeder, but it won't presurize. There's no leaks from the lines, caliper, or master cylinder.
    Any ideas??
  22. MiCarl
    Turn handle bars all the way to the left, this will get the outlet of the MC as high as possible.
    Keep bleeding, rap the top banjo bolt lightly to release air. Do it for 20 minutes.
    Repeat 3 evenings in a row.
    Unless the MC isn't working it will firm up.
  23. RickCoMatic
    Prepare your work area for making a mess.
    Cover the Tank with a towel ... a layer of aluminum foil ... another towel.
    Crack loose the Banjo Bolt holding the Master Cylinder to the Brake Line.
    Snug it so it stops leaking.
    Here's what we got to do ... so get the stuff you need together.
    We have to Pull the Banjo Bolt and tie-up the Brake Line ...
    Don't worry about the Master Cylinder leaking-out while you tie-up the brake line.
    Now then ...
    Take the Banjo Bolt and find a solid bolt with same threads.
    Wrap that Bolt with a couple of turns of teflon thread-sealing tape.
    Place that bolt in your shirt pocket (or where you can reach it with your other hand on the Master Cylinder.)
    Bottle of New Brake Fluid handy.
    Paper Towels Galore.
    OK ... let's get nasty.
    Fill the Master Cylinder.
    Hold your Thumb pressed to the Outlet.
    Pull the Brake Lever to the Grip
    Remove and replace thumb
    Release Brake Lever
    Repeat the above procedure until the Master Cylinder is:
    1. Tested
    2. Bled
    If the Master Cylinder Seals are in need of replacement ... Brake Fluid will not be drawn from the reservoir and pressure at the Outlet will not be strong enough to push-off your thumb.
    You'll need a Kit in there ... or, a new Master.
    If the Master ... DOES bleed and pressure moves your thumb off.
    Stick that wrapped-up bolt in there.
    Loosen the bolt and let brake fluid leak out when you Pull the Lever a few times ...
    Then, ...
    Tighten the Bolt so it will NOT Leak and Pull the Brake Lever.
    If the Brake Lever is:
    "Spongy"
    Pulls right down to the grip.
    Does NOT hold hydraulic pressure.
    The Master Cylinder FAILS testing and corrective measures are necessary.
    If the Lever HOLDS Pressure.
    Replace the Brake Line.
    The Master Cylinder is bled and will pump fluid to allow the system to be bled.
  24. DanP
    DanP Member
    Newmarket, Ontario
    Well, I've ordered a whole new master cylinder. It was cheap and mine looked pretty beaten up. There were scratches in the bore and I guess once I cleaned all thet gunk out the seals weren't able to hold the presure. New part should arrive in a few days.
  25. RickCoMatic
    Bingo!
    You'll be back in-action right-quick!
