Cam Chain Adjustment - Rick's Method Works Beautifully
Discussion in 'XJ Technical Chat' started by redcentre003, Feb 8, 2009.
  1. redcentre003
    redcentre003 Member
    "Rick's Method Works!"
    Kept hearing funny noises from the top end of the engine, couldn't pinpoint the problem and then thought...maybe I'll give the cam chain a tweak and see if I can tighten it.
    Remembered Rick's method - timing cover of...turn clockwise a couple of turns and then anti clockwise quickly. Heard a "clack" from inside and there you go - obviously the automatic cam tensioner just needs some manual assistance. But the motor sounds much better and tighter now and not like it's got a metal mouse running around inside it.
    In 1985 Yamaha terms, "automatic" cam chain tensioner probably meant it automatically adjusts when you manually intervene...!
    k.
  2. XJ700VET
    XJ700VET Member
    Portland OR
    One thing I like about this site is the ablility to cut through the tech speak in the book and, get to the meat and potatos of the fix in a very clear way. I've learned so much from the other contributers of this site as well. There can't be enough said about the folks that freely share their time & knowledge here with others. Thank you, to all those that give, there are many that you'll never see that are in your debts.
  3. David3aces
    David3aces Member
    St. Pete Fl.
    Back in the early 80s when a noisey auto tensioner style bike came in, we would take the cap off and push on the plunger until we heard 1 click. Every one became real quiet. We came up with this because the bikes were just too noisey. Customer's loved it. We could only do it with a Snap on 3/8th air ratchet with out pulling the carbs.
  4. dwcopple
    dwcopple Active Member
    bay city, michigan
    Step by step...please...you need the motor in neutral right? then use a socket or a wrench on the crank? should it be easy to turn it?...pull the plugs too right?
