can z900 shims be used?
Discussion in 'XJ Technical Chat' started by jimgoose, Jun 27, 2010.
  1. jimgoose
    jimgoose New Member
    My friend is about to tackle the valve shims on his 1982 XJ550 maxim. I have loads of spare shims left over from servicing my '76 Z900 & '77 Z1000 over the years. I just wondered if anybody knows if these Kawasaki shims are the same as the ones used on the XJs?
  2. mwhite74
    mwhite74 Member
    I doubt it, there's probably minute difference in the diameter of the shims. If you have a micrometer or whatever you could probably measueran XJ one and compare to the ones from the Kawis...
  3. jimgoose
    jimgoose New Member
    Just an update, I bought a genuine Yamaha shim size 250, part number J7-12169-A1, and it is identical to the left over shims from my 1976 Z900. Exactly same diameter & same right-angled corner. I used a couple of my Z900 shims in my friends 1981 XJ550 and they worked fine.
