Can't remove float pin!
Discussion in 'XJ Technical Chat' started by carlos102090, Jul 14, 2011.
  1. carlos102090
    carlos102090 Member
    I am trying to clean the carburetor and got stuck trying to get this little pin out. it just seems like its stuck in there. any ideas?
  2. bigfitz52
    Yes. Use a small drift or a "nailset" to tap the pin out just far enough to get a sharp pair of diagonal cutters under the head, and carefully use those to pry and pop it out.
    Be sure to support the float "tower" when tapping, and you don't need to tap very hard. The "binding" part of the pin is the area just under the head, the shaft is a slightly larger diameter just there.
  3. SQLGuy
    SQLGuy Well-Known Member
    Or you could make a pair of these
  4. ktp1598
    ktp1598 Member
    Mount Washington
    1. Heat the head side of the tower with a heat gun.
    2. Cool the pin with freezing spray. I used contact cleaner.
    3. Use needle nose pliers to push pin flush.
    4. Use diagonal cutters to wedge pin out by head. Absolutely worked great for me!
  5. carlos102090
    carlos102090 Member
    FINALLY DID IT!! i spent two hours last night after work and two hours this morning trying to take this thing out.thank you guys, the work can now continue
