Carb "Main and Pilot AIR jets"
Discussion in 'XJ Technical Chat' started by Bjarvis, Aug 29, 2012.
  1. Bjarvis
    Bjarvis Member
    Victoria BC Canada
    Sorry for the basic questions but - first time on this forum" spent several hours trying to find the answer to this question. I took the carbs off a 1980 Maxim to clean. - obviously they had been taken off before by previous owner as the the jets were not the same places in all 4 carbs. So I am not sure which way they should go back. - I have jets numbered 195 and 66? - which is the pilot air jet which is the main air jet() After removing diaphragm and removing the gold screw/plate the two air jets were underneath - Looking at the Air jets from the top with the jets on the right side of the chamber which is the Main Air Jet port and which is the Pilot air jet port ? or to asking another way is the larger hole jet the Pilot or Main air jet. Secondly which goes where ??
    I know the fuel jets are on the bottom of the carb inside the fuel bowel - with the larger jet #110 the main fuel jet. It is the Air jets that are the confusion.
  2. mlew
    mlew Well-Known Member
    Apex, NC
    The pilot air jet(large hole jet) goes to the front(throttle plate side) of the carb.
    The main air jet(small hole jet) goes to the rear(air intake side) of the carb.
  3. wilddog
    wilddog New Member
    Be aware that the Haynes manual has at least one illustration with the jets reversed.
  4. RickCoMatic
    AIR Jets are OPPOSITE from FUEL Jets.
    The LARGER AIR Jet is the PILOT AIR Jet.
    The SMALLER AIR Jet is the MAIN AIR JET
  5. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    If these are reversed what effect would it have on fuel consumption?
  6. chacal
    Horrible, and it would run rich as all get-out..........
  7. schmuckaholic
    California
    The jets were fine. The LABELLING was backwards.
  8. tabaka45
    Brunswick, Georgia
    Perhaps 33 mpg!?
