CARB settings?
Discussion in 'XJ Technical Chat' started by cly_adams, Apr 20, 2010.
  1. cly_adams
    cly_adams Member
    LISLE,IL
    Hi everyone, After a long winter and deciding not to sell my Xj! I figured its time to get it back on the road and actaully clean the carbs. Cleaned the carbs did the whole 9 yards it looks purrrrty! Clean as a whistle. Problem is I dont remember the settings on the mixture screws, The Throttle screws and the main Idle adjuster. I read through quite a number of treads found a good starting point for the mixture screws at 2.5ish out. Whats a good way to adjust the throttle and idle adjuster? Do I do the bench synch? to figure out the throttle screw settings? Any help would be great. Its a 83 Xj550 maxim with Minuki carbs.
  2. yamaman
    yamaman Member
    Staten Island, NY
    yes do the bench sync. Rick's method with the 3x5 cards cut into 1/4" strips is good. they must be 1/4", you'll know why when you're doing it. set the idle screw so it holds the card enough to where when you pull the paper out, you feel the same drag on all of them. Then leave the idle screw there till you start the bike, then you'll probably have to back it down a bit. I can't comment on Mikuni's but yes I read 2.5 is about right for a starting reference point.
  3. cly_adams
    cly_adams Member
    LISLE,IL
    is there one way or another that is better? i was reading about using 2 paper clips. Would the index card or paper clips make for any else adjusting?
  4. HalfCentury
    HalfCentury Member
    Virginia Beach, VA
    Did you adjust your valve clearances?
  5. cly_adams
    cly_adams Member
    LISLE,IL
    No not yet, I need to order a new valve cover gasket, So I figured I'd wait to do that till I have the gasket. Im not going to do a full synch on them yet I just need to get it in the ball park, Im just looking to get the bike running, Like it was before I took the carbs off :lol:
