Carb stand for float adjustments
Discussion in 'XJ Technical Chat' started by supero1, Dec 11, 2008.
  1. supero1
    supero1 New Member
    Smyrna, Georgia
    Parts List:
    1. Threaded rod : 3/8" and 3ft long piece. Cut mine to 9"
    2. Nuts (10) 3/8"
    3. Washers (4)
    4. L shape bracket and original carb bracket to hold carbs : 3/4" by 1/2" and 1/16 thickness
    Cut mine to 15" long.
    5. Base : U shape piece of aluminum or steel : I got my piece which was
    laying around my friends house. It came from Sears but don't
    know what it was used for. You want something that won't bend when
    using the c clamp to hold it down. Cut mine to 15"
    6. One piece of wood (2 X 4) 5" tall
    (Check the photo Description notes on how to use unit.)
    Updated 12-21-08
  2. grmeyers
    grmeyers Member
    Asheville, NC
    Re: Making a carb stand
    Now you need to show us how to use it please.
  3. bigfitz52
    Good idea; the only modification I might suggest would be to alter the design slightly to "engage" the carb rail rather than replace it so there isn't as much disassembly/assembly required to use it.
  4. MiCarl
    Pulling the rail also risks mis-aligning the butterfly shafts.
  5. supero1
    supero1 New Member
    Smyrna, Georgia
    Sorry it took me so long to update. If been pretty busy at work.
    I have updated photos and notes. In the photo below I'm thinking of cutting these areas out so the steel carb bracket will stay connected at all times to the carbs to keep carbs from being misaligned.
  6. HalfCentury
    HalfCentury Member
    Virginia Beach, VA
    I like the stand. Its a nifty engineering solution.
    Personally, I consider the float height job to be too small for such an effort of time to make a stand.
    10-15 minutes on a flat surface with a block of wood for a leveling jack and its done.
