Carb Woes
Discussion in 'Hangout Lounge' started by triump, Mar 31, 2008.
  1. triump
    triump Member
    Mississauga, Ontario
    Ok. I have taken these things apart about 15 times now. Each time it was of something that I missed and people here suggested I should check this or that. And more often then not I did miss it. So now I think I have them clean. The bike is a little hard to start but do start. Runs okay with choke. Warms up nicely and idles good after warm with no choke.
    So now for my problem. When I crack the throttle just a little ( Snap it ). The bike rev shoot up to about 5 grand and hang for a bit then slowly comes back down to idle. I have checked for air leaks and can not find any. I used a propane torch to check for leaks.
    Can anybody offer any help. This bike is beating my up. I originally bought this bike for a parts my for my daily runner but after I got it running it seemed to be a shame to scrap it. So I think I am going to try to put it on the road but these carbs are killing me.
  2. RickCoMatic
    It sounds like the Diaphragm Pistons aren't coming back down as fast as they should when you close the Throttles.
    Search: "Clunk Test" Author: RickCoMatic
  3. chacal
    Could be a number of things, but it sounds suspiciously like your brass-plated vacuum diaphram PISTON is hanging up in it's bore slightly, making it difficult to return to its closed position (thus keeping the main fuel needle lifted up and passing lots of fuel!).
    The solution, as RickOMatic has so eloquently stated, is to polish the carb piston bore with 600/800/1000 grit paper to get it smooth as a baby butt, and a brief, quick polish of the brass piston too.......untilt he piston will drop back down through it's bore with a no-friction, no-resistance "clunk" when released.
  4. Ass.Fault
    Ass.Fault Active Member
    College Station, Texas
    crazy thought: reversed the throttle/choke cables?
  5. triump
    triump Member
    I have done the clunk test with no probs. And I didn't reverse the choke a throttle cable.
    I was thinking the clunk test thing at first. But what happens is this. If I give a quick twist of the throttle the rpms shoot up to about 5 grand then slowly come back down. Now the quick twist should only bring the rpms up to about 2 grand so I am not turning the throttle much.
    Does this lead anyone in a different direction. Would the air mixture screw cause this prob. maybe the screw is set to lean? Just a though.
  6. Alive
    Alive Active Member
    Queensland, Australia
    The air mixture screws only effect fuel/air mixture at around 2k rpm and below above that it is taken over by the needle depth.
    Have you synced them?
  7. triump
    triump Member
    I bench synced them.
  8. Desinger_Mike
    Desinger_Mike Member
    Eastern Pennsylvania
    Really DUMB question, but I gotta ask.
    Are the springs in decent shape (and accounted for) on top of the diaphragms?
  9. triump
    triump Member
    Yeah. I wish it was that easy.
  10. Polock
    are the "choke" plungers all the way down, with a little to spare ?
    with the bike not running twist the throttle all the way open and let it snap back
    do you hear a definite sharp clunk when they close ?
  11. triump
    triump Member
    Nope. Choke is closed and there is a clunk.
  12. Polock
    YICS port bolts are tight, with the copper washers ?
    is this a test?
  13. Gamuru
    Gamuru Guest
    Granite Falls, WA
    I second this question. I had hanging rev's that cleared up after a carb synching.
  14. RickCoMatic
    Intermittent High Revving can be caused by a number of things:
    Most Common because of design and age:
    Sticking Diaphragm Pistons
    Linkage Problems
    Stuck Linkage
    Weak Return Spring
    Weakened Sync Screw Springs
    Sticking Throttle Shaft Seals
    Improper Tuning and adhustments:
    Pilot Mixtures way off
    Wrong Pilot Jets
    Misplaced Jets after Carb Cleaning
    (Air and Fuel ++ Uppers and Lowers)
    Tight Cable
    Wrong Cabling
    Air Leaks:
    Manifolds Leaking
    Air Boots Leaking
    Throttles:
    Improper Sync
    Damage
    Stuck-open Butterfly
    Air Jets:
    Misplaced Air Jets (Haynes misprint)
    Missing Main Air Jet
    Improper reassembly of the Carb rack by and inexperienced mechanic.
    Swapped Main and Pilot Jets (Hitachi)
    Stuck Enrichment Valves
    Enrichment Valve Linkage dirty and not alloowing valves to close.
  15. chacal
    Life, is a test.........
  16. RickCoMatic
    Yes. This is just a test. In the event of a real emergency ...
    (I got Carb Cleaner on Sale this week at AutoZone)
  17. MrShake
    MrShake Member
    Normal, IL
    Farm and fleet had it on sale for 99 cents a can as well :)
  18. triump
    triump Member
    When I switched the pilot and the main jets this problem went away. Do that point the finger to a more specific problem.
    I can sync the carbs because I don't have a YCIS tool. The best I can do is a bench sync.
    Thanks for all your help.
  19. Ass.Fault
    A tool can be improvised.
    I have used cotton strips knotted together soaked in Marvel Mystery Oil.
    Stuff them in and it blocks the passage, also cleans the "Maintnence Free" passage.
    Learned this one from Rickerstein
  20. RickCoMatic
    That "YICS Stuff" was a stroke of pure genius.
    I have gotten emails from around the Gloge on that one.
    Glad to have come-up with it and started the ball rolling in here!
  21. willierides
    willierides Member
    NY
    Clogged or undersized pilot jet.
