Carbs coming off this weekend
Discussion in 'XJ Technical Chat' started by patmac6075, Oct 11, 2013.
  1. patmac6075
    patmac6075 Active Member
    MKE
    Set the valves last weekend and now it's time to get those carbs "zestfully" clean.
    I'll be pulling the carbs off the Seca and I'm looking for the good tutorials (hopefully pertaining to a YICS 750)..
    My carbs are going to be completely disassembled and soaked in carb cleaner.
    Any help is appreciated.
  2. fiveofakind
    fiveofakind Well-Known Member
    San Diego, CA
  3. GEHIV
    GEHIV Member
    Willow Grove, PA
    I the 2nd article the by Rick Massey, go old school.
  4. BruceB
    BruceB Active Member
    Isle of 8 Flags, Florida
    FYI- if you are NOT planing to break the carb rack and replace all the fuel rail seals and associated items, it is not recommended that you soak the entire carb in carb cleaner. It will lead to leaking seals.
  5. patmac6075
    MKE
    Thanks to all...
    It will be a complete breakdown (hopefully in the carburation sense, not the mental health sense).
  6. patmac6075
    MKE
    So far so good!
    Carbs came off within 20 mins. (Bike is mostly dismantled)..
    Got them completely stripped and #1 is beginning it's 24 hr. soak.
    The only issue was the drain plug was completely buggered up.. had to break out the drill and EZ Out.
    No turning back from here.
    Thanks again for the tutorials...
  7. davec
    davec Member
    ontario canada
    dont soak them..
  8. bigfitz52
    You can soak them as long as you've removed the butterflies and throttle shafts and completely stripped them.
    You are correct in that they should not be submerged if the throttle shafts/seals are still intact.
  9. patmac6075
    MKE
    Thanks Dave & Fitz...Carbs are already soaking...and they have been completely stripped.
  10. patmac6075
    MKE
    I should have parts arriving from Chacal today....I do have one question on the shaft seals...I seem to remember somewhere reading that the seals have a ribbed side and a smooth side...would make sense that the smooth side seals up against the carb body...Am I correct in this assumption?
  11. schmuckaholic
    California
    Actually, I don't really think it matters. I did a writeup years ago on replacing the throttle shaft seals, and I didn't make note of which way they went on.
  12. biggs500
    biggs500 Active Member
    Sherwood WI
    As far as I could tell the shaft seals Len sells can go in either way. Rather than being a true "V" seal like the factory ones these have more of a cross section similar to a tiny "I" beam, at least that's the best I can describe them. The aftermarket seals are much beefier that the factory ones also. I've replaced them in three racks and every one seals up fine.
  13. bigfitz52
    Lippy side out if they're not symmetrical.
