Carbs suck ..... in more than one way.
Discussion in 'XJ Technical Chat' started by dmlyster, Aug 10, 2013.
  1. dmlyster
    dmlyster Member
    Corvallis, Oregon
    Been gettin a lot of carb help from here on XJBikes, thanks. But not yet done as you can see from the subject line.
    Got it to lite-up but have had nothing but problems with running smooth and color-tune / YICS tool. Using homegrown YICS too was able to get good color out of #3 & 4. Number 2 was all over the map and #1 showed nothing but a white color.
    Oh God help me! Removed YICS and after several sequences of idle mix screw was finally able to blue color on #1 at about 1/4 turn from bottom. Okay, opened back up YICS ports and tried tool again, no blue, basically all white and hard to even keep my darlings heart running.
    Anybody want my YICS tool?
    Any thoughts, helpful or humerous?
  2. dmlyster
    dmlyster Member
    Corvallis, Oregon
    Couldn't help it, had to feel it out of the garage and under load. It ran worse that is sounded during tuning. Missing, jerking under low rpm, good for a second under 5K rpm then missing again and losing power. Was trying for 4 mile round trip .... headed back home for 2mi round trip, I really didn't want to walk farther that that.
    Bike ran really smooth prior to full carb job (float bowl leaking started this), don't know were to go with this, junk yard keeps coming to mind.
  3. dmlyster
    dmlyster Member
    Corvallis, Oregon
    oh yea, and after making sure valve clearances are in spec (shanged 3 shims) it sounds like I have a valve that wants to escape the head!
    You don't use the YICS tool when adjusting for mixture; it's only to be used during a running carb synch.
  5. dmlyster
    dmlyster Member
    Corvallis, Oregon
    Thanks, that differs from my understanding of another thread post. I'm trying everything so I'll go this direction. Checked plugs after most recent ride (so to speak) and both #1 & #3 plugs are carboned up real good.
    Obviously rich, so I'll continue from here.
    Thanks again!
  6. kleraudio
    kleraudio Member
    Erie, CO
    Did you get a good bench sync then a good vac sync?
    If so, you're done with the YICS tool. Shouldn't be used when doing colortune.
  7. RickCoMatic
    Re-do your Bench Sync.
    Use strips of 3X5 Card.
    Before you reinstall the Carbs; smoosh some RTV on the Manifold to Head Joints.
    Install the Tool.
    ColorTune for Idle.
    Blue is good Idle, ... But you need a bit more richness to get out-of-the-hole.
    Get the Blue.
    TWEAK --> Out ... Until the BLUE fades due to the additional richness.
    From there you should be able to Vac Sync OK.
  8. dmlyster
    dmlyster Member
    Corvallis, Oregon
    Yep, used 3X5 card strips for my bench sync. Vacuum sync took a few times but ended very consistant (with YICS tool).
    First attempt at color-tune was terrible (no YICS tool) and would get no color regardless of where I turned the idle mix screw ...... just white flash, no blue, no orange, no yellow. Thought it was not getting fuel, checked bowl level ..... perfect. Went back to Yics tool, getting some orange, okay, went back to NO YICS finally got blue color. Took quick ride (thought I would have to walk home) #1 plug seriously carboned up.
    I get blue but doesn't matter where I turn mix screw to ....... it's still blue but idle sure changes.
    driving me crazy and don't want to pull the carbs again!
  9. RickCoMatic
    Check for air leaks.
    Check that AIR Jets are correctly placed.
    Remove Pilot Mix Screws.
    Inspect for Flattened O-ring at bottom.
    Assure O-ring and Tiny Flat Washer NOT "Flipped-over"
    (O-ring above Flat)
    Flush top to lower passages.
    Pilot AIR through Pilot FUEL
    Block Pilot Fuel orifice.
    Flush Pilot AIR thru Mix Screw orifice.
  10. MercuryMan
    MercuryMan Active Member
    Springdale, NWA
    Your valves should have a nice rhythmic tapping at idle. It should be an equal amount (sound wise) of this coming from any one of them. It isn't loud but it isn't quiet either. Anything different and something isn't right. If you have a valve that is too loose it will be really loud, too tight and you won't hear it at all until it's too late.
    You might have had a shim riding above the bucket when you measured and it settled in after to go REAL loose-I'd go back in and check clearances before you mess with the carbs again. Once my shims are back in I drizzle them with oil and crank the mill over several times to 'bed' them in before I do the final measurement.
    By all means don't give up. A bike that is running at all is ALWAYS worth saving....that is unless it's a rusty old nighthawk 250!
  11. RickCoMatic
    IF the Valves are IN Spec, ... then HEARING them is GOOD!!!
    The Valves are Closing real tightly, ... transferring Heat to the Seat for Cooling.
    I fuss to have the Valve train .004 on Intakes and .005 or .006 on Exhaust.
  12. bigfitz52
    Not so. Mixture tuning using the ColorTune is our "visual substitute" for the EGA that Yamaha used for mixture tuning. Yamaha specifies the blocking of YICS for the EGA procedures (mixture tuning) as well as for sync.
    The reason for this is that with YICS not blocked, you're "reading" a combination of the cylinder you're working with PLUS the other 3, via the YICS passages. With it blocked, you've isolated the cylinders from each other. So if you're seeing an issue with one particular cylinder with it blocked, then that carb (or cylinder) does indeed still have some sort of issue. Possibly a vacuum leak.
  13. k-moe
    You are correct. I mis-remembered the procedure.
  14. dmlyster
    dmlyster Member
    Corvallis, Oregon
    Thanks all .... I'm still not convinced my YICS tool (homemade) is actually blocking ports. So until I have confidence everything else, it seems, have several confounding factors which introduces unknown results in this carb sync.
    What I do know is that the unrelated from YICS tool is the valve noise. I only modified 3 valve shims. *no. 2 intake *no. 3 exhaust and *no. 4 exhaust. The noise seems to be originating on the left side the. So no.2 intake change is where I start my exam.
  15. bigfitz52
    Just go back and re-check all of your clearances.
  16. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    With any carb issue, valve clearances always are questioned. I would recommend re-checking your clearances just to rule that out. Just an FYI, valve ticking or fluttering sounds are happy sounds.
    After that, I'd take a look at that homemade YICS tool....
  17. dmlyster
    dmlyster Member
    Corvallis, Oregon
    I love that normal valve ticking ..... but this is out there. So yea, off comes the valve cover again.
    For me to have any confidence in YICS tool I'm going to need to buy one. Shipping costs are terrible for one item purchases.
  18. bigfitz52
    From Len???
  19. dmlyster
    dmlyster Member
    Corvallis, Oregon
    Actually costs are good from Len ..... But going back is another story. Sent SS brake lines back and that was bad (still compaining). Will get YICS tool from him, hope it is fool-proof cause it seems this fool will find it if there is a fault.
    Just finished re-check of valve shim clearance ..... all still within spec. Maybe valve noise because fuel mix is so rich and piston skipping a beat?
  20. jmilliken
    Dillsburg, PA
    Off topic, but how dis you ship back? Just use priority mail flat rate boxes
  21. dmlyster
    dmlyster Member
    Corvallis, Oregon
    UPS wont ship to PO Box so had to go USPS. Brake lines don't fit in any of their standard anything fits box so had to use normal process. $15.
