Changed oil, now it stalls!
Discussion in 'XJ Technical Chat' started by Speedwagon, Apr 27, 2006.
  1. Speedwagon
    Speedwagon Member
    Littleton, CO
    I changed my oil yesterday, and now the bike stalls when I go to put it in gear. What's up with that? Am I not checking the oil level properly? I can see oil up to the top line of the window, though it is already quite a bit towards the black side.
  2. Brian750R
    Brian750R Member
    Boston MA
    sounds more like a sidestand switch issue than an oil issue. See if the switch is operating correctly with a multi meter if you have one, other wise clean the contacts and try again.
    Its normal for new oil in an old engine to appear dirty quick, consider putting some seafoam in the crankcase a few hundred miles before you do another oil change.
  3. Speedwagon
    Speedwagon Member
    Littleton, CO
    Ok, I'll try testing the switch then.
  4. woot
    woot Active Member
    What oil did you use?
    What tempature is the air?
    Is this only when starting the bike first time in the morning?
    Could just be the clutch plates sticking with a heavier weight oil...
  5. Speedwagon
    Speedwagon Member
    Littleton, CO
    Um.. yea..... Did I mention that I had disconnected the battery, to check the water level? And I did some cable rerouting?
    Side stand switch was disconnected. Whoops. :D
  6. woot
    woot Active Member
    Didn't see that post ;)
    Glad you found the bug! :D
