Changing to round gauges 82 XJ750
Discussion in 'XJ Technical Chat' started by mook1al, Feb 12, 2012.
  1. mook1al
    mook1al Member
    Talladega, AL
    Hi all. I am changing the gauges and such on my 82 XJ750 Maxim to the round style as used on the 80-83 650 and 83 750. I know I will have to get a mechanical tach drive cable, but I am unsure of where it mounts at the engine. Can someone post a pic of where this tach cable attaches?
  2. hogfiddles
    Being that it's an 82, are you sure that it's mechanical? If you're current gauges are electrical, then you still need electrical tach. If your current tach is cable driven, then all you have to do is hook the cable to the new tach.
    In any event, if you are switching to a cable -driven tach, the port for the cable is on the front of the engine on the head between pipes 3 and 4. If you can't find it, pm me and I'll send a pic of where it is on the earlier 650's
    dave f
  3. mook1al
    mook1al Member
    Talladega, AL
    hogfiddles pm sent
  4. schmuckaholic
    California
    Speedo is mechanical. Tach is electrical.
  5. mook1al
    mook1al Member
    Talladega, AL
    Yep, Hogfiddles pointed that out to me. The 81 gauge cluster I bought it as close to ment as one could find, but I didn't know at the time that I would have to have an electrical tach. So...I bought an ok set of 83 gauges for twice the price, and when it arrives, I will take the faces and covers from the 81 and put them on the 83 unit. I just hope that I can get the needles off without breaking them, as that is the only real challenge in disassembling a gauge cluster.
  6. NS_Rider
    NS_Rider Member
    So will the 83 gages work directly on the 82? I also plan to replace the square gages and head light on my 82
  7. tcoop
    tcoop Active Member
    South Weber, Utah
    They are not plug and play. Some re-wiring will need to be done, but they will work.
  8. LVSteve2011
    LVSteve2011 Member
    Las Vegas NV
    Hello Mook, are you planning to sell your old gauge cluster?
  9. mook1al
    mook1al Member
    Talladega, AL
    LV, I hadn't planned on selling the old cluster. However, I wouldn't mind helping out a fellow XJ'r. One of the reasons I am changing other than personal preference is that the outer case is broken on the right front side of the cluster. But, everything on the unit functions properly and is in good order.
  10. LVSteve2011
    LVSteve2011 Member
    Las Vegas NV
    Howdy Mook, wouldn't ya know it! it's same part messed up by a PO. Mine has the left side corner sheared off by road rash. Thanks any way.
  11. LVSteve2011
    LVSteve2011 Member
    Las Vegas NV
    I know how you feel about giving up the 650, they are fun.
  12. dustdustin
    dustdustin New Member
    kokomo in
    I brought a tach for my 1982 Yamaha xj750 seca and I cant figer out the wiring for it its a 5 wire tach I know that 2 of the wire is for the light I got that done but I don't know where I hook up 3 of the other wire go to pls help :roll:
  13. Polock
    one is +, one is -, the other is signal from the - side of the coil. that's the side that goes to the TCI, and might be a gray wire but not sure
  14. dustdustin
    kokomo in
    The + and the - do I hook to the battery or the coil pos and negthxs
  15. dustdustin
    kokomo in
