check your cables!
Discussion in 'XJ Technical Chat' started by fuferman, Mar 30, 2009.
  1. fuferman
    fuferman Member
    Kettle Falls, WA
    so i got stranded a few miles from home when my throttle cable snapped. right at the end. i walked home and returned with some tools and a plan.
    using an old bicycle brake lever i jimmy rigged a thumb throttle to get the bike home. when i got the cable off it was worse than i thought. not only where it snapped off was bad but the whole cable was rusty and another spot was barely hanging on by a string.
    i used the brake cable from that same old bike. in the outer sheath that was on my motorcycle to make a new throttle cable. the carb side of the old cable had a floating end piece that i slipped over the end of the new cable and soldered to make the end stop. now i have my old normally functioning twist throttle back.
    originally i only intended this to be temporary to enjoy the weather but i think it should last a real long time.
    any ways check your cables and lube lube lube!
    what do you guys think about this repair job?
    [​IMG][​IMG]
    [​IMG][​IMG]
    [​IMG][​IMG]
  2. Tiny
    Tiny Member
    Battle Ground, Wa
    I plan on replacing all my cables and brakes and everything saftey related one at a time as soon as money allows. I your solution but I probably wouldn't use it longer than needed.
