Checking wires on kickstand switch
Discussion in 'XJ Technical Chat' started by joejr2, Aug 17, 2021.
  1. joejr2
    Santa Fe,NM
    I put together my 82 xj650 seca rj out of parts from a variety of sources. I have an oem kickstand switch and
    a wiring harness from another 650 seca rj. there are three wires from the switch; blue with yellow stripe,
    black, and green with blue stripe. the connector has only the black and the blue with yellow. does the green with blue have to connect somewhere. I have been trying to get the solenoid to fire the starter motor and have been trying to eliminate any possible causes. have tested the sidestand and cutoff relays, ( ok ) Horn works neutral light goes on with the key and the oil light goes on whe starter button is pushed. I've swapped out about 4 different starter relays with no change. any sugestions ?
