Choke control
Discussion in 'XJ Modifications' started by 82NewToMe, Feb 3, 2013.
  1. 82NewToMe
    82NewToMe Member
    Harrisonburg, VA USA
    Since all the mods, I don't have a choke control on the handlebars anymore.
    Anyone else relocated a choke control on a xj750? Pics? Thoughts? Ideas?
    Thanks in advance.
  2. barrygeorge001
    barrygeorge001 Member
    this is on a 650 but they are the same. I got this from lowbrowcustoms.com
  3. 82NewToMe
    82NewToMe Member
    Interesting. Thank you. It gives a great idea, I'll mount one like it to the frame right under the tank (on the smaller tube) and use a really short cable, I don't really have the room on my handlebars. I have 1" drag bars with HD controls. This way it could be easy to access but hidden. Thanks again.
  4. darkfibre
    darkfibre Member
    Perth, Australia
    I don't use a cable, I just hold up the choke rod linkage by hand on the right hand side for the 10-20 seconds I need it in winter.
  5. bigfitz52
    Boy that choke lever looks familiar...
    Standard fare on British bikes from the '50s through the '70s.
    ('74 Norton Commando.)
  6. sebwiers
    sebwiers Active Member
    Looks like it function ally is similar to the thumb shifter from my early '80 MTB. I wonder if those would work for choke control? Might take some drilling to get the cable end to fit right, but they have a fair amount of pull (maybe 30mm). If they would work, they'd be a nice option - quite compact, easily bar mounted, high quality aluminum construction. Shame that modern thumb shifters all suck.
    Vintage down tube clamp on shifters could also be cool, especially if going for a frame mount. Much easier to find (and cheaper, and in more styles) than thumb shifters. Also very easy pull apart and modify. If you want to get fancy, you could even do a braze on for the mount, instead of a clamp. Hmm....
