Clarification on starting problem
Discussion in 'XJ Technical Chat' started by timotheos, Aug 26, 2014.
  1. timotheos
    timotheos Member
    East Wenatchee, WA
    I'm an ignorant mechanic, especially when it comes to electrical issues. I've ridden this bike for two years now, and yesterday I rode it, stopped, went outside to start it and it only clicked. I spent time looking through the forums for the same problem, and printed out the electrical FAQ. I took out the battery, filled it, charged it, the battery place said it was still good. Put it back in, still only clicking.
    Now, do I:(1) check all the switches/relays and clean them; (2) what? check voltage in various places? I have a pretty good mutimeter. Even reading the various answers, I'm still not sure how to check things next. Part of my problem is ignorance of terminology, but I have chacal's guide to where the relays are. Are switches and relays the same? A new starter solenoid relay is only $10 on ebay, but am I right in understanding that if it clicks, the solenoid is still good?
    Thanks for your patience.
  2. 12Rant
    12Rant New Member
    Nortern Ontario
    I'd first try the solenoid With the tranny in neutral turn the key to the on position and use a screw driver (with an insulated handle) and touch the two leads on the solenoid if it cranks over it's probably the solenoid.
  3. hogfiddles
    My bet is the battery is NOT good. Hook up the jumper cables to you car and try it again.
    Dave
  4. timotheos
    timotheos Member
    East Wenatchee, WA
    Thanks. I'll try the battery, and then the solenoid.
  5. timotheos
    timotheos Member
    East Wenatchee, WA
    Do I need to do anything differently, or have particular motorcycle cables when I try to jump it?
  6. schmuckaholic
    California
    Not really. Negative to the engine block, positive to the battery, hit the button. I've had to jumpstart the bikes twice, and each time I used standard automotive jumper cables.
  7. hogfiddles
    That's right.... No different. Just don't stand on the car's accelerator pedal, though!!
  8. timotheos
    timotheos Member
    East Wenatchee, WA
    So it wouldn't start with the jumper cables connected, so I was going to take it to the top of this little hill and bump start it. I put it in neutral, walked it up, and when I got to the top of the hill, I pressed the starter and it started. Why would it do that then? Kinked wire? Bad connection? I'd like to trace it out if I can before I take it anywhere else. You guys are great.
  9. bigfitz52
    Old tired original solenoid.
    Buy a better quality part than the $10 eBay one. While you CAN use virtually any starter relay, like one from a lawn tractor, I'd recommend a good quality replacement so it doesn't just fail again.
  10. hogfiddles
    It was afraid you were going to push it over a cliff.....
  11. schmuckaholic
    California
    I'd go with "just to fark with him". Won't start on flat ground, but let him push it up a hill...
    FYI, Len's part number for that is HCP449 for OEM, and HCP1680 for aftermarket.
  12. SLKid
    SLKid Active Member
    Troy, Va (Charlottesville)
    Lol agreed, Solenoid :)
    If you gotta keep charging your battery I'd replace that too.
    Wal Mart Batteries last for like 2-3 years
    Interstates last for like 3-4.
  13. jason191918
    jason191918 Member
    Weston, WI
    if you hear a click, the solenoid might be good. You ever jump the terminals to see if it starts? Could also be bad spot in the starter.
  14. Mike82mxm
    Mike82mxm Member
    Ste,Annes,Manitoba,Canada
    bad starter button? dirty inside? i had the same issue cleaned up my start button works fine now.It must make a good contact.
  15. timotheos
    timotheos Member
    East Wenatchee, WA
    I replaced the old (prob. 3+ years) battery, replaced the solenoid, cleaned the connection at the starter button, cleaned all the relays that are under the seat/in the battery area. And it still just clicks. Starter?
  16. jason191918
    jason191918 Member
    Weston, WI
    like i said...if it clicks, the solenoid is most likely good and it is a starter problem. Mine did the exact same thing a couple of months ago. Brushes were shot. Take the starter apart and see if the rotor drops in or if you need to spread the brushes.
  17. timotheos
    timotheos Member
    East Wenatchee, WA
    Yeah, just hoping it was something else first :)
  18. timotheos
    timotheos Member
    East Wenatchee, WA
  19. timotheos
    timotheos Member
    East Wenatchee, WA
  20. fiveofakind
    fiveofakind Well-Known Member
    San Diego, CA
  21. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Re-visit the right control switch. Tighten the screws for the "run-off" switch. The screws have vibrated loose causing the schetchy start. I fixed this same issue on my bike today.
    Gary H.
  22. timotheos
    timotheos Member
    East Wenatchee, WA
    Thanks. I did print out that great description of rebuilding the starter. You ain't kidding about those screws. What and where is the run-off switch?
  23. fiveofakind
    San Diego, CA
    on the right handle bar...you don't have a kill switch....off...run switch...that is odd ....!!!!!
  24. timotheos
    timotheos Member
    East Wenatchee, WA
    Oh, ha, I read that as "run-off," as in "sewer run-off".
