clicking when trying to start engine
Discussion in 'XJ Technical Chat' started by boldstar, Jun 11, 2013.
  1. boldstar
    boldstar Member
    ABERDEEN.SCOTLAND
    hi guys,bike as of lately been running great went out to start it this morning ignition on press to start. click click click. sound seems to be coming from starter area checked fuses checked all connections including battery connections all seem good.even tried to jump start off car [engine off] still just clicking.any help would be great thanks in advance guys.
    The clicking is the starter solenoid, and that's a good sound to be hearing. What's not so good is the lack of the starter motor turning. It may be time for it to be pulled so you can clean the commutator and replace the brushes.
  3. boldstar
    boldstar Member
    ABERDEEN.SCOTLAND
    k-moe thanks for the prompt reply swapped battery tried my mates 1 started up 1st push of the button.now time for a new battery i think as this one is three years old.thanks again P.S. was thinking of checking out the brushes anyway good call k-moe
  4. tonzo
    tonzo New Member
    Rochester, NY
    I'm having a similar issue but I just got a rebuilt starter so I don't think that's the issue. Will a weak battery cause the starter to not turn over and for the taillight to temporarily go out when trying to start? My starter solenoid is clicking as well
  5. k-moe
    A weak battery can indeed allow the solenoid to work (the clicking) but not be able to turn the starter motor. Put it on a charger and see if it will take a full charge. If the battery is more than 3 years old I would just get a new one.
  6. RickCoMatic
    Sometimes, ... the Solenoid clicks and the Starter fails to spin because the Electrical-end of the Starter is overly contaminated with Carbon Dust from the Brushes.
    Check the Brushes.
    Douche the Electrical Housing, Brushes and Commutator with a strong spray of Isopropyl Alcohol.
    Buy a Plastic Bottle at the Rx Store.
    Stick the Seal with a finishing nail.
    Squirt it right-out of the bottle.
    Keep squirting until what drips-out is as clean as what you spray-in!
