Clutch cable
Discussion in 'XJ Technical Chat' started by KiLo, Feb 27, 2011.
  1. KiLo
    KiLo New Member
    hi all, I just changed my clutch and now i have like 1 cm of extra slack in the cable. Everything is lined up where it is suposed to be. im stuck any help would be sweet.
  2. ManBot13
    ManBot13 Well-Known Member
    Fairfax, VA
    You adjust the cable at the engine case, and fine adjust it (and as it stretches) at the lever. Also, you can move the throw arm on set of teeth at a time. Search for RickCoMatic's post on clutch adjustment.
  3. bigfitz52
    back the actuator arm up one set of teeth on the throwout shaft.
    What bike? We could give better advice yet if we knew that...
