Clutch cover the same on 82 750 Seca AND Maxim?
Discussion in 'XJ Technical Chat' started by ryanismyname, Jun 4, 2010.
  1. ryanismyname
    ryanismyname Member
    Baltimore, MD
    I park my Seca on the sidewalk on the side of my house to avoid cars backing in to it. Well last night while I was at a show some asshole pushed it over. I've had neighborhood kids toying with it before but never anything like this. Anyway, when it went down, the brake pedal perforated the clutch cover and put a 2" by 1" hole in it. Ebay has a lot of Maxim 750 covers. Will they fit???
  2. stereomind
    stereomind Active Member
    Tulsa, OK
    The part numbers are different, but as far as I can tell, they are identical.
  3. chacal
    Yes, they'r the same as far as fit goes. The difference in part numbers is due to the different finish on the covers.
  4. ryanismyname
    ryanismyname Member
    Baltimore, MD
    Thanks Chacal. I just made an offer on one for $20 and it was accepted. What's the deal with the gasket? Do you sell one, or can I just use a liquid one?
  5. chacal
    Hey Ryan, yes, we sell the correct gasket (paper) that is used for the covers.......although you can use some type of gasket-making material, we don't recommend that, as it makes a real mess to remove the cover in the future!
    While you have the clutch cover off, you may wish to inspect your clutch and re-fresh the disc, drive plates, and springs/bolts while you're in there......
