Clutch Friction Discs from maccycle?
Discussion in 'XJ Technical Chat' started by mtnbikecrazy55, Sep 6, 2012.
  1. mtnbikecrazy55
    Anyone heard of them or have any experience with them?
    They sell a set of 8 friction discs for 48.00.
    http://maccycles.com/Search.aspx?k=xj750
    Reply to an email:
    "Yes I carry the clutch plates for the 1983 Yamaha XJ750 Maxim they are 48.00 for the set of 8 fiber plates.
    Sorry I do not carry the bolts, the springs, nor the gasket.
    Jan"
    Anyone know of a cheap place to find the plain plates? My clutch has been slipping a bit more lately and I fear that me putting off the rebuild for too long has made it so that its going to cost me more money now :cry:
  2. wwj750
    wwj750 Member
    central minnesota
    You shouldnt need new plain plates as long as yours arent warped or burned. Just clean em up real good with some scotchbrite.
  3. jeffcoslacker
    jeffcoslacker Member
    SW MO
    I sure wish I could remember exactly what I bought for the XJ650 clutch...I'd buy the same set for the 750 now if I needed it.
    Got the stuff from JC Whitney, a set of Kevlar impregnated discs and 20% over springs, separate items, for around $90 total, seems like.
    Was very happy with the performance of the clutch after that. Never could pull a wheelie on that thing even when the clutch was still good...after, it was no big deal...in fact did the first unexpectedly doing a high-rpm holeshot...woohoo! Then I found that I could give the throttle a couple of pumps in first gear and whack it, and she'd stand up and beg. Probably woulda been better off not knowing all that...some powers can only be used for evil...
  4. bigfitz52
    TRUE. XJ4Ever has your springs, washers, gaskets, etc. Plus "aftermarket" friction plates (K&L) competitively priced.
  5. mtnbikecrazy55
    I had planned on getting the gasket/springs/bolts from len if not found cheaper elsewhere.
    I was going to get the friction discs from him as well, but the price is double: (Hence why i was wondering if anyone had experience with other ones)
    Clutch Friction Discs:
    HCP3192 OEM clutch PRIMARY FRICTION DISC, compressed, treated cork material discs provide the grab and the go for your clutch. Brand new replacements prevent clutch slippage and return the original performance to your clutch. Fits all XJ550, XJ650, XJ700, XJ750, and XJ900 models, use 8 per clutch. Each:
    $ 12.95
    HCP3192SET8 OEM clutch PRIMARY FRICTION DISCS, set of 8:
    $ 99.95
    HCP1641 Aftermarket clutch PRIMARY FRICTION DISC, compressed cork material discs are a standard oem-replacement quality and material. Fits all XJ650, XJ700, XJ750, and XJ900 models, use 8 per clutch. Each:
    $ 14.95
    HCP1641SET8 Aftermarket clutch PRIMARY FRICTION DISCS, set of 8:
    $ 117.95
    HCP10978 Aftermarket clutch PRIMARY FRICTION DISC is made from a high-performance Kevlar material for the ultimate in street performance! Fully segmented design insures the greatest coefficient of friction and durability. All XJ650, all XJ750 air-cooled, and XJ900 models use 8 discs per clutch, while all XJ550, all XJ700 models, and XJ750-X (water-cooled) models use only 7 of these discs per clutch and the one additional secondary friction disc (HCP10975) listed below. Each:
    $ 18.95
    HCP10978SET7 Aftermarket clutch PRIMARY FRICTION DISCS, set of 7:
    $ 129.95
    HCP10978SET8 Aftermarket clutch PRIMARY FRICTION DISCS, set of 8:
    $ 144.95
  6. RickB
    RickB Member
    Southern Maryland
    [quote="mtnbikecrazy55]I had planned on getting the gasket/springs/bolts from len if not found cheaper elsewhere.
    I was going to get the friction discs from him as well, but the price is double: (Hence why i was wondering if anyone had experience with other ones)"[/quote]
    So where did you end up getting your parts from? I'm looking too. I've seen some EBC friction plate kits on eBay for ~$60.00 delivered...
  7. mtnbikecrazy55
    So where did you end up getting your parts from? I'm looking too. I've seen some EBC friction plate kits on eBay for ~$60.00 delivered...[/quote]
    Did you see my reply In your thread?
  8. RickB
    RickB Member
    Southern Maryland
    Did you see my reply In your thread?[/quote]
    I did; thanks again for your help.
