clutch problems... help needed
Discussion in 'XJ Technical Chat' started by cbcanada, Jun 29, 2012.
  1. cbcanada
    cbcanada Member
    hey guys with all the help from the guys on the from even a newbie like me got an old 1981 xj750 working. oil chang and cleaned carbs
    one final piece remains.
    i had taken off my clutch cable and put it back on. and now i find two things happening.
    1. the clutch is slipping since i put it back on. when i have clutch lever pulled in the bike moves very very slightly sometimes.
    2. it is very hard to change gears. very stiff. this was the case before i took off the clutch cable but since then not only is it still hard to change gears but its near impossible to go into neutral.
    any advice is appreciated
  2. FJ111200
    FJ111200 Active Member
    Crewe, Cheshire, England
    So out of 24 views of this topic, not one person has asked you, have you adjusted the cable?
    There should be about 2 to 3 mm play at the lever end, that is the handlebar end. I don't know if there should be any play at the actual clutch end, as it's about 20 years ago when i was last familiar with the 750.
    Check the cable for fraying at both ends, 'cos if it is frayed it's about shot.
  3. ManBot13
    ManBot13 Well-Known Member
    Fairfax, VA
    See RickCoMatic's clutch adjustment thread: http://xjbikes.com/Forums/viewtopic/t=2672.html
    If you completely removed the cable, you likely disturbed the adjustment on the engine side of the cable and will have to adjust that end before making the fine tuning adjustment at the lever.
