Clutch slip at high speed??
Discussion in 'XJ Technical Chat' started by kcoop99, May 19, 2010.
  1. kcoop99
    kcoop99 Member
    BFE, Nebraska
    So my bike is running pretty damn good but as always, there is always something....
    When I get out on the open road and am running about 5000 rpms in 5th gear and I open it up to go faster (pass another car for example :twisted: ) it seems to not be grabbing until it gets to around 6500. So it does grab but it takes a while. Could my clutch cable be too tight, as in not enough play, or is this something with the clutch? Thanks!
  2. snowwy66
    snowwy66 Member
    Salt Lake City, Utah
    loosen the clutch cable a little and see if it helps. it might be too tight and not be releaseing all the way. if that don't help then the clutch is slipping.
