Coils and wires question....
Discussion in 'Hangout Lounge' started by blueskyb2t, Dec 2, 2010.
  1. blueskyb2t
    blueskyb2t Member
    Qc Canada
    Hi friends!
    Need your help once more.. :oops:
    Is it possible to change the spark plugs wires without changing
    the entire coils... No magic tricks? :twisted:
    It's for a 750 maxim 1983.
    Tanks a lot!
  2. mlew
    mlew Well-Known Member
    Apex, NC
    Which bike?
    Short answer is yes and no, most Yamaha ignition coils have the wires molded in. It is possible to replace them with some coil modification. Not really a easy job but it is possible.
  3. blueskyb2t
    blueskyb2t Member
    Qc Canada
    It's a 750 maxim 1983... oups.... ;)
  4. BillB
    BillB Active Member
    Tulsa Oklahoma
    there are instructions on here about dremel tooling out the coil and replacing the wire then filling in the coil with epoxy
  5. chacal
    We carry aftermarket plug wire "splicers" that allow you to replace the part of the plug wire outside of the coil.....the splicer allows you to splice the new plug wires onto a short stub of remnant wire where it exits the coil body.
    Rarely does the wire inside the coil body get damaged, but if it is, then coil surgery or new coils is the way to go.....
