Color Tune Question
Discussion in 'XJ Technical Chat' started by Germinator3, Aug 14, 2007.
  1. Germinator3
    Germinator3 New Member
    Mid Michigan
    Got a "Gunson" Colortune system early last month, came for a 12mm plug. Works great on a XJ550, but I've got an '81 XJ650 that takes 14mm plugs. :evil: It's too late to return this, does anyone know if a 12mm to 14mm adapter exists out there?
    Thanks - Tom
  2. PghXJ
    PghXJ Member
    Pittsburgh PA
    give the 12mm plug to me. :D I could use one.
  3. BlueMaxim
    BlueMaxim Active Member
    Central Mississippi
    Not from Colortune. They only make reducer adapters to use the 14mm plug with 12 or 10mm plug threads. May be able to find some for a 12mm pressure gauge that you use to read cylinder compression.
    I found it! Check here:
    http://www.etoolcart.com/index.asp?Page ... rodID=5053
  4. Robert
    No, and I wouldn't advise an adaptor. Why not spring for just the plug of the correct size for your application? Chacal has them, check out his Parts For Sale thread on the For Sale forum. The Gunson company also sells just the plug for folks that have multiple applications.
