Colortune
Discussion in 'XJ Technical Chat' started by AlexDonaghue, Sep 3, 2012.
  1. AlexDonaghue
    AlexDonaghue Member
    Anyone have a good how to thread for colortuning?
  2. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    I saw a couple of good things on youtube. But just follow the instructions and be aware that the blue flame will cover a rather large range on the pilot screws--or at least it did on my XJ700. Since I couldn't hear a change in rpm's except at the end of the ranges, I decided to count the turns from the initial blue flame (coming from rich) to the drop off in rpm's at the lean end, and set the pilot screw half way between, then watch the plugs and adjust the pilot screws as needed. Just be sure the choke is off, the engine is warm, and the idle is set. Other folks may have had different results and if so I'm sure they will let you know. Good luck.
  3. AlexDonaghue
    AlexDonaghue Member
    How do i know what size mm kit to buy?
  4. Groundswell17
    Groundswell17 Member
    Maryland, US
    personally, for me, it wasn't worth it, i had a closer tune without it, used that, and screwed it all up and had to start over. just my 2cents
  5. jobee58
    jobee58 Member
    Denmark, EU
    If I remember correctly I found the info on the manufacter's site itself.
  6. maverickbr77
    maverickbr77 Member
    Lowville, New York
    same as you spark plugs 14 mm
  7. AlexDonaghue
    AlexDonaghue Member
