Converting from stock bars to clip-ons
Discussion in 'XJ Modifications' started by Hakoo, Apr 1, 2015.
  1. Hakoo
    Hakoo New Member
    United States
  2. Hakoo
    Hakoo New Member
    United States
  3. Beekman
    Beekman XJ Grasshopper
    Erin, Ontario
    Based on my limited experience, yes it will be a good idea to replace your lines. Changing controls over to a different set of handlebars should be pretty straightforward.
    If the brake master cylinder on the bike now is a "tilted style" you may need to switch to a flat one for perfectly flat bars. (See the xj4ever link and go to the master cylinder section for more info, this also depends on if you use the stock mirror mounts or not I believe)
    I recommend getting proper length lines because most stock Xj bars have some kind of rise to them, most clip on bars I see are very low so you will have lots of extra cable wiggling around. Something you definitely do not want in your hydraulic brake lines.
    Not to mention the fact that it would be visually unappealing to have extra lengths of throttle and clutch cable sticking out or looping around near your bars
    The best search results come for using Google. Enter your keyword(s) followed by....
    site:xjbikes.com
    I find that method to work better for all internet forums.
  5. Iamwayno
    Iamwayno Member
    MI
    You say it's something you don't want with your hydraulic brake lines. Why is that? What would happen if the wiggle too much? Or is it just not a good thing to have extra lines?
  6. JPaganel
    JPaganel Well-Known Member
    Minneapolis
    Lines and cables that are too long can kink . They also look terrible.
  7. Beekman
    Erin, Ontario
    Also with a excess length cable you are more prone to the cable "flopping" (for lack of a better word) around, causing unnecessary stress on the connections.
  8. Iamwayno
    Iamwayno Member
    MI
    Ok thats what i thought. I was just planning on finding a way to coil and zip-tie any excess cable neatly.
