Converting to a Spin-on Style Oil Filter
Discussion in 'XJ DIY How-To Videos' started by BaldWonder, Apr 3, 2015.
  1. BaldWonder
    BaldWonder Innocent Bystander
    Oberlin, OH
    Al2023, Franz, Hand and 7 others like this.
    Len sells the specially machined socket that you need to install the adapter. It's the same size as you need for the clutch basket nut and a few others, so it's worth getting (unless you have access to a lathe to machine your own socket).
  3. BaldWonder
    Oberlin, OH
    Hah, not unless I can make the socket out of wood! Yeah, I'll be asking him for one soon. I just cracked the clutch case open today to try to suss some things out, so I won't be putting oil in until I get a new gasket, so I might as well get the socket too while I can still redo it oil-free. I didn't read the instructions close enough to realize the thin nut needed to be torqued, not just snugged, hence I didn't get it with the kit.
    To be clear, the only machining required is to thin the outside of the socket wall so it can fit into the recess for that nut. A person with a drill press, a file, and a lot of patience could make one.
  5. BaldWonder
    Oberlin, OH
    If they had any 30mm sockets at my local hardware stores (trust me, I checked them all), then I might have the patience to go with my file and press. Alas...
  6. JPaganel
    JPaganel Well-Known Member
    Minneapolis
    Auto parts stores have them.
  7. chacal
    Very nice!
    BaldWonder likes this.
  8. SnoSheriff
    MB, CAN
    Awesome tutorial. Thanks!
  9. Polock
    the nut holds the adapter plate to the engine, so does the oil filter. All the nut does is hold the pipe out so the filter can screw on to it the proper distance.
  10. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
    Nice job.
  11. Maxim-X
    Maxim-X Well-Known Member
    London Ontario Canada
    For what it's worth some people suggest pouring some fresh oil in the filter before installing, a little messy but the idea is that you won't get a dry start when you start it the first time after changing the oil.
  12. k-moe
    It has been scientifically proven that an XJ can be run at full throttle for almost an hour without any oil at all in the sump.
    Well not exactly scientificaly. Some biker trash tried to blow one up at a rally several years ago, and failed.
  13. BaldWonder
    Oberlin, OH
    I think I saw that one. Didn't he have to eventually pour gasoline on it or something after like two hours?
  14. DanTaylor
    DanTaylor New Member
    USA CO
    hey what did that conversion kit cost you? I couldnt find it on Lens page
  15. BaldWonder
    Oberlin, OH
    hmm... uh... $80 something? You expect me to keep receipts? God, you're like my CPA. ;)
  16. DanTaylor
    USA CO
    dangit man your supposed to know this stuff! =P
  17. BaldWonder
    Oberlin, OH
    DanTaylor likes this.
  18. DanTaylor
    USA CO
    Thanks mate
  19. NickV
    NickV New Member
    New York
    How do I order the conversion kit? I don't see an option anywhere
  20. NickV
    NickV New Member
    New York
    How do I order it?
  21. chacal
    Send me an e-mail at: info@xj4ever.com or use the "Start A Conversation" feature on this website!
  22. NickV
    NickV New Member
    New York
    Awesome Thanks
  23. kempertime
    kempertime New Member
    Edmonton, Alberta
    What is better about a spin on oil filter?
  24. k-moe
    Faster oil changes, more filter media choices, no fighting a stuck or rounded-off filter housing bolt, no losing the rubber washer. But mainly it's a preference, not a must-do.
    kempertime likes this.
  25. XJ550H
    on a 550 if you use a mac 4 to 1 exhaust the spin on filter will fit between the headers , where the stock filter housing will not come out between them.
    you have to roll it to remove filter
  26. kempertime
    Edmonton, Alberta
    Just getting started here, so thanks for the reply
  27. XJ550H
    what bike do you have?
    if you click on your user name at top of page , then click signiture you can add your bike there and we will all see it in your posts.
    like you can see under my post. this is helpfull to us all
  28. kempertime
    Edmonton, Alberta
    Ok thanks, I just bought a 83 XJ 750 Maxim for 500 bucks.. drained the fuel tank, changed oil, new spark plugs, new battery and she fired right up!
    Andrew Nichols and Wintersdark like this.
  29. XJ550H
    I got one earlier this year and an 82 as well working on both of them . 82 was running when I picked it up but has a chopped frame:(
    rebuilding the carbs for the 83. 82 has pods bad gas mileage and plugs get black quick can not wait to dig into those carbs to see what po did to rejet for pods..
    500 is a good price for a running bike
  30. SR500ED
    SR500ED Member
    Smithville Ontario Canada
    Other than being faster to change the oil filter what is the advantage of this conversion?
    Ed
  31. BaldWonder
    Oberlin, OH
    Far superior filtration over stock.
    Jetfixer likes this.
  32. SR500ED
    SR500ED Member
    Any data on this? Just want to know if the initial expense is worth it.
  33. BaldWonder
    Oberlin, OH
  34. BaldWonder
    Oberlin, OH
    Also, converting to this style eliminates the oil cleaner cover, the easy-to-strip by-pass bolt, and all the other associated o-rings and seals needed when performing an oil change using a stock system. These are all things that don't come with the stock filter replacement. You lose or damage one of those things, you'll have to order (and wait for) a new one.
    Andrew Nichols likes this.
  35. SR500ED
    SR500ED Member
    Makes sense to me. Only thing that kind of bothers me (my paranoia) is that some tweeker will unscrew it a parking lot.
    Thanks for the reply and info.
    Ed
  36. BaldWonder
    Oberlin, OH
    Well, at the risk of making you more paranoid, someone could do all kinds of stuff to your bike in a parking lot. At least with the oil filter, they're likely to burn their hand hitting the headers in the process.
    chacal likes this.
  37. cgutz
    cgutz Well-Known Member
    SE South Dakota
    I don't have a conversion kit, but have been changing stock oil filter in mine since new. I figure I probably have 60+ filter changes under my belt (about 2x/season).
    What makes the conversion attractive to me (other than ease and less mess) is the fact that I have to look at a diagram just about every time I change filter to make sure the washer, spring, filter, etc. are going on in right sequence and correct orientation.
    I guess it hasn't been attractive enough to actually modify. I also resist because everything else (except brake lines, brake pads and spark plug caps) are basically what came on the bike off the showroom. I want to keep it as much "survivor" as I can.
  38. k-moe
    I have yet to do this, but if one uses a mini oil filer there should be enough room in the facory filter housing to machine it into a cover. There might even be just enough room to make it work with the larger oil filter.
  39. SR500ED
    SR500ED Member
    If I changed my oil filter that often I would probably go for the conversion.
    You can always change it back to stock.
  40. k-moe
    He doesn't change the oil too often (excessively). Cgutz bought his bike from a Yamaha dealer when it was brand new.
    cgutz likes this.
  41. cgutz
    SE South Dakota
    ding, ding, ding.....
    I wonder how may Xjer's have "original owner" bikes? I think there was a thread some time back, but not many people joined.
    I've posted this picture before, but just for fun....Polaroid of a proud owner of a brand, spankin' new XJ...I had more hair then, and it was brown. Less gut too....
  42. XJ550H
    I print photos and hang them on my wall with torque specs for oil changes, chain adjustment torque specs ect just a glance away.
  43. SR500ED
    SR500ED Member
    I'm the third owner of my bike, but I've owed it the longest, 28 years.
    Ed
  44. cgutz
    SE South Dakota
    I have this same photo on my phone now, but have to make sure I call it up before my hands are oily...
  45. kosel
    MInneapolis, MN
    And yet, it's the shoes that always make me laugh!
  46. Franz
    Does anyone have a list of spin on filters that are suitable for our bikes?
  47. Dave in Ireland
    Ireland
    I use the Mann W67/1 which is perfectly adequate, and a bloody good make, but I intend to put a slightly longer one on next change.
    https://catalog.mann-filter.com/EU/eng/catalog/MANN-FILTER Katalog Europa/Oil Filter/W 67~1
    Observe the filter rubber ring seal dimensions and the fixing thread, plus an anti drain-back valve and relief valve pop-off pressure.
    This is the longer one...
    https://catalog.mann-filter.com/EU/eng/catalog/MANN-FILTER Katalog Europa/Oil Filter/W 610~3
    If you can be arsed, you can look through the list of equivalents, but Mann filters are available everywhere via Amazon or even your local motor factor.
    Franz likes this.
  48. Franz
    Cheers Dave l have used Mann filters before and had no problems with them.
    The Haynes manual states the factory bypass valve setting pressure is 0.8 to 1.2 bar and the relief valve opening pressure is 4.4 to 5.4 bar.
