Cracked Carb Boots...
Discussion in 'XJ Modifications' started by MadCowInk, Mar 21, 2009.
  1. MadCowInk
    MadCowInk Member
    Hey,
    Has anyone tried coating thier cracked carb boots with Plasti-Dip? It should seal them, just wondering how well it would hold up.
    Later;
    JC
  2. snake61047
    snake61047 New Member
    Freeport,Il
    I just got done doing it. it took 3 coats but they look and sealed up geat.
  3. wamaxim
    wamaxim Active Member
    Vancouver, USA
    Did you dip part way up the wire? If so, how far up?
    This is a great idea!
  4. P2Fabrication
    P2Fabrication Member
    New Jersey
    Agreed! Ours looks like they've seen better days...
  5. snake61047
    Freeport,Il
    What I did was brushed on the plasti dip. I tried dipping one but it got messy. I went from the base to the clamp area.
  6. DianCecht
    DianCecht Member
    Central Illinois
    I think there was someone on the board that had tried this, and he said the overtime the plasti-dip seemed to disappear. I've heard the liquid electrical tape suggested in the same fix, but it seems that everyone stresses these methods to be temporary fixes. Let us know how it goes though, or how long it lasts... Might give someone the chance to save up enough pennies while they ride.
  7. snake61047
    Freeport,Il
    I tried the liquid electrial tape first because I couldn't find the dip. I was a joke and seemed to melt in contact with the gas.
  8. bigfitz52
    I've had good luck packing the cracks with black ADHESIVE RTV silicone gasket sealer.
  9. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    I used GOOP to seal the cracks in mine and painted them black with high heat paint.
  10. Gunk
    Gunk Member
    Maybe a job for plastisol. That's the stuff that comes in those vinyl repair kits. It's a heat curing synthetic rubber.
    T-shirt printers buy it by the gallon for shirt printing. It's also used in manufacturing for car carpets, that's what makes the carpet form to the shape of the floor pan.
    Dirt cheap stuff too, usually cures at about 300ºF
    It's available for about 19 bucks a quart on Ebay.
    I'm going to pick some up for experiments.
  11. midnightblu
    midnightblu Member
    Austin, TX
    i cant believe it took me this long to dream this up.... i am sitting here reading through the posts thinking to my self that wont work for one reason or another ... not heat resistant ... wont stand up to fuel... etc the light bulb comes on Fiberglass. fiberglass is heat resistant, can be shaped, will bond to rubber / plastic etc, can be sanded / drilled / painted, can be layered for added strength.... only one pitfall.... if you dont make it strong enough it will crack, easy fix 2 - 3 layers of fiber.
    just some food for thought. fiberglass kits are $7.99 at the autoparts store
    if somone has already tried this please chime in
  12. ktcubed
    ktcubed Member
    St. Augustine, FL
    Not sure about the glass idea. I think you would loose the flexibility of them and getting them on/off would become an issue.
  13. PainterD
    I've used fiberglas to repair mufflers because the hotter it gets, the harder it will become. I'm not too keen on the idea of using it for sealing the intakes however. It may develop cracks in it over time and leave you back at square one again. I may be wrong and it's worth a try I guess.
  14. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    I think fiberglass would crack out and leave you with the same problem. I like the plastic dip or the liquid electrical tape method. Remember that when you remove and install the carbs you put a bit of pressure on those boots. I didn't have carcks on the last 1100 I bought but just from removing the carbs now I do. A member out east wants it and I'm just going to get some new ones from sporting for less and put them in for the guy. He wants to fly in here and ride the bike home about 1300 miles. Don't know if they would fail or not. I would feel better about it if I were on the road for that long. Just my thoughts.
  15. PainterD
    Mn-Maxims makes a good point (you da man!)
    I didn't look at it that way, but it does make sense. When installing or removing the carbs, those boots will flex somewhat and end up cracking the fiberglas in time, unless you put it on ...real, real thick. I'd look at using something else instead.
  16. P2Fabrication
    New Jersey
    Can we still get the carb boots new at the dealer?
  17. TheHound
    TheHound Active Member
    Scotia, NY
    If you're masochist.
