Cracked cylinder block
Discussion in 'XJ Technical Chat' started by Fraps, Apr 9, 2008.
  1. Fraps
    Fraps Member
    Kitchener, Ontario, Canada
    How can I easily tell if my cylinder block is cracked? I have a couple of spare XJ engines that I picked up years ago and I was told one of the blocks had a crack in the cylinder wall. I can't see anything obvious.
    I would rather not put it into operation to find out!
  2. RickCoMatic
    Usually a Cracked Block is rather obvious. It's a Cracked Head that can be almost invisible.
    The "Old School Method" is:
    Tie it up an suspend it from something overhead.
    Use a screwdriver handle or a hammer handle and "Ring" it.
    If it has a flat, dull ring to it ... it's suspect!
    If it "Rings True" then it might be OK.
    The right way is to have it checked-out by a Machine Shop.
    They'll either X-Ray it or Magna-Flux it to inspect for a crack; someplace.
  3. TIMEtoRIDE
    If it's off the engine, machine shops will Magna-flux it free !
    just bring it in clean. That's for the iron liner only. Aluminum cracks take a process of spreading on a dye, then a "developer" that shows cracks.
    That one might cost a little.
  4. Fraps
    Fraps Member
    Alrighty then. I'll try the old school method first of beating it with a hammer to see if it screams in tune.
