Cutting bolt off oil filter housing
Discussion in 'XJ Technical Chat' started by avengingllama, Sep 21, 2008.
  1. avengingllama
    avengingllama Member
    Columbus, Ohio
    Hey guys.....I am dremeling away on the oil filter bolt but it doesnt seem to want to release. Is the large section that looks like it is a washer acually the part I should be cutting or just the 9-11 mm section? I say 9-11 mm because it was so misshapen that I can't tell what size it WAS. lol Thanks for the info =)
  2. bill
    bill Active Member
    Raleigh, NC
    It was 12mm :D
    The washer is part of the head. The whole thing is a "Pipe" with a head. The pipe part is threaded at the far end and is the part that threads into the engine.
    You need to cut out carefully from the nut part until you can get the filter cover off. Then you can remove the pipe part.
    Hope that makes sense I don't have a picture.
  3. ZaGhost
    ZaGhost Member
    Dartmouth, Nova Scotia
    Cut away that washer looking section and you can probably turn the rest ut by hand (I could)
  4. MiCarl
    Sears (and other places) sell a stripped bold/stud extractor set.
    Makes quick work of that bolt. And you don't have to worry about damaging the filter housing.
  5. nsosh5
    nsosh5 Member
    oklahoma
    i bought an aftermarket bolt rather than the oem. The aftermarket has a bigger head an won't strip aa easy
  6. NursePadawan
    NursePadawan Member
    Lansing, MI
    I had to use a pair of channel-locks to get the bolt off of mine. Promptly replaced it with a new aftermarket one I bought from Chacal (and even remembered the anti-seize on the threads). Cutting that bolt out would an absolute last resort if vice grips failed to get it off.
  7. coachholland
    coachholland Member
    Georgetown, KY
    I had to get the sears set for mine, they come in sizes from 10-18 mm. The thread was so badly damaged, the 12 mm wouldn't hold, so I used the dremmel to grind it down to around 10 mm, then used it the sears 10 mm to get it out. If you're less than 10 mm, it's likely the bolt won't come out even with the sears tool.
    Definitely order one from Chacal after you're done. Sourcing the bolt from the dealer is going to set you back $50 or more!
  8. avengingllama
    Columbus, Ohio
    unfortunately I am at the "last resort" part of the project :( I have tried the vice grips as well as the damaged bolt removal set from sears. The bolt is so badly hosed that I could not get a bite on it with either of them. I have already taken the head of the bolt off, which in hindsiht was probably a mistake, I should have tried to "recreate" a head by grinding away with the dremel. So now I am just hoping to be able to get a bit with a screw extractor set.
  9. RickCoMatic
    Drill successively larger holes right smack dab in the center of the end of that bolt.
    Then, grind away at the Inside Diameter of the Shouldered Section of the Bolt until you get the Shouldered Section to just fall off.
    The Filter dome will be released.
    The, grab the remainder of the Big Bolt with an angry-jawed Pipe Wrench.
    The trick is to not destroy the Machined end of the Dome.
    Just grind away the steel.
  10. bill
    bill Active Member
    Raleigh, NC
    Not sure an extractor will do the job. even the largest one you could find I would think would be too small.
    I hope it works for you but I'm afraid you are at the point you will need to carefully remove the washer part....
  11. avengingllama
    Columbus, Ohio
    trying the successively larger bits now. when the housing is ready will it just pull off or does it twist off like an oil filter on a car?
  12. bill
    bill Active Member
    Raleigh, NC
    Once you get it free if should pop off - there is a spring.
  13. RickCoMatic
    Once you get to the Outside Diameter of the hollow bolt ... the Filter Dome will become loose.
    There NO threaded area.
    The Shouldered Area of the Bolt supplies force to compress the Dome to its Seat where an O-ring seals it.
    Grind away the Bolt Material of the Shouldered portion.
    Once you grind-off the Shouldered part of that Bolt from the inside ... you're home free!
  14. avengingllama
    Columbus, Ohio
    thank God it's not something that I will need to guess about.....lol. I am ok with obvious. *continues drilling
  15. avengingllama
    Columbus, Ohio
    Hey guys, just wanted to let you know that I ended up getting the bolt out. =) After cutting away portions of the washer part, I used larger drill bits until I drilled a hole just large enough to insert the largest extractor I had, used a big freaking crescent wrench (about a foot long) and gave it the old heave ho! and BLAM!! out it came =) now I just have to figure out where the little orange o-ring that came with the fram oil filter goes. Looks to me like it should go on the "top" of the oil filter bolt where the threads are. But I get the feeling you are going to say that it actually goes somewhere else.....lol. Thanks for all the help guys and your patience. Hopefully at some point this thread helps someone in the same predicament.
    Edited because after reading I even confused myself. lol
  16. Ease
    Ease Member
    NL, Canada
    Just for the record, Yamaha sells the aftermarket bolt, not OEM (at least my local dealer did... $21 bucks CDN)... even they figured out the olt head was too small. ;)
    Congrats in finally getting the bolt out.
  17. MiCarl
    Yes, it goes somewhere else.
    Near the "head" end of the bypass bolt there is a groove. The orange o-ring goes in there to seal the bolt to the housing.
  18. RickCoMatic
    Nice work getting the darn thing out!
    The small O-ring fits a groove on the Bolt just below the Shoulder.
    It makes the end of the Bolt Oil-tight at the Inside Diameter of where the Bolt passes through the Filter Dome.
